funnel augers breaking
    Re: funnel augers breaking
    i'm sure there are photos of it, but not a close up of it.
    it's nothing more than a sectional cable that's been cut off at the open wind. then i heat the end section t allow for a bent hook. then oil quench it. sharpen the end andput a bend on it.
    i'll have to post a photo over the weekend when i get out to the truck.
      Rick, you constantly come up with amazing stuff. Are you, by any chance, a plumbing savant?
        Sounds like it has been proven that the 3/4" drum cable and augers are junk.
        Right? Wrong?
        Thanks.
          I want to put different Manuf. funnels in a vise. Adapt. a Mech. torque wrench to them and
          see what happens to each! Please send $5.00 each to the Tool fund. care stoney lonesome
          { San Quentin Prison .}
            Now Mrs. J. will have to go buy bigger pillows and install ADA doors.
            Shhhhhhhhh.....
              I have been having a problem with breaking the augers as well and have gone through 3 in the last couple months.
              I took some photos of a broken one next to a brand new one. You can see where the break occurs. You will also see how the broken auger is stretched out. The winds of the auger near the connector are very tight on a new auger and stretched out loose on the broken one.
              It appears the whole design needs a re-work.
                nice analysis dakota
                • #23
                  dakota, was that the 7/8'' or the 1.25'' cable auger?
                  try using my reverse auger design you'll never go back to the ones you're having problems with
                  i busted up 3 in 1 day at the same job. i then used my reverse auger design and have never broken it. even running the cables in reverse have not harmed them.
                  the auger is also bendable to allow for it to make it into the 1.5''- 2'' lines and then spring open to the 3''-4'' lines.
                  this is what makes the k-60 so universal. it cuts on the clockwise and counterclockwise rotation
                  • #24
                    does anyone find it interesting/disturbing that no one from Ridgid has chimed in here?
                    i'm pretty aggressive sometimes and have bent several augers but never broken one. usually the bending comes from damaged pipes with the hook end catching while the cable continues to spin
                    any response from Ridgid would be nice
                    steve
                    • #25
                      steve, believe me they are reading the forum and this thread. i don't believe they need to answer every concern as they have in the past.
                      go back to the day allclear came on and started posting. he raised a stink about everything from augers, to couplings, to cables, to feeder bearings. just to name a few from memory
                      the forum works good to share our experience both good and bad. along with ideas good and bad. although we might not see an immediate fix, they are aware of it by our post and am pretty confident they will come up with a fix.
                      in the mean time, my reverse auger is the best specialty cutter/ auger i own and it didn't really cost me a dime. the cable was already damaged and non repairable as the last few feet was wasted. so now i have a 12' auger that has cleared more drains than i can remember
                      • #26
                        The auger problems were with the 7/8 sectional. As for the reverse auger, I am totally sold and will be throwing one together. I have yet to damage a section of 7/8 yet, but did just get in a length of the 7/8 IC to use at the front so I could probably sacrifice one of my old 7/8 sections to make the secret weapon!
                        • #27
                          dakota, you are planning on coming to the long beach phcc show may 1 correct
                          never to late to join team geritol
                          don't ruin a good cable yet. but then again a good cable cost the price of 2 augers that get trashed pretty quickly
                          we'll also be in van nuys on april 6th too
                          • #28
                            it looks to me that when welded there was undercut into the auger?
                            please post a closer pic of the failed weld and auger as well.
                            Sent From The StoolBus
                            www.appletondrainandsewer.com
                            Appleton WI, 54915
                            1-920-284-7471
                            • #29
                              I feel Brazing would be better in this application. It would flow in and have more contact surface, Less Temp. I will say it was really torqued to bend out like that.
                              Does General wire have this problem?
                              • #30
                                Rick,i knopw they are reading but as i stated, "any response from Ridgid would be nice"
                                steve
