K-7500 feeder bearings?
  • K-7500 feeder bearings?
    I ordered a new set of feeder bearing for my K-7500. Part number 60752 from a very well renowned Ridgid retailer .
    The 3 bearing I received are made in Korea
    Yes stamped 63xxx Korea ?????
    I called Ridgid and the OE part and replacement part are made in Japan?
    What the heck is going on ?
    Every replacement Ridgid part I have every ordered has been in a Ridgid bag with the part number on it. These 3 bearing were not in a Ridgid bag, and where in like a peppermint package?
    P.S. everything else I ordered was in a Ridgid bag or box ?
    I don’t really care where it is made just as long as when I order a replacement part it is the same as original
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: K-7500 feeder bearings?
    wasn't there a post just like this a couple days ago? Along with some good replies?
    Man my mind is not working 100% Brings up the quote I got on my facebook. "The advantage of a bad memory is that one enjoys several times the same good things for the first time."
      Doesn't sound good to me. The Factory bearing should be an NSK bearing, and it should definitely be in a RIDGID 4x5 polybag. The print could be a stickered label with the part # on it. But usually the print will be right on the polybag.
        no its a Korea bearing.
        if you wish to call me fell free
        Appleton WI, 54915
        1-920-284-7471
