Best pressure washer for conversion
  • Best pressure washer for conversion
    How are you all doing? I'm new to the forum and was wondering if anyone would know which pressure washers make the best conversion to a jetter? I am looking to buy a washer off of craigslist or something in hopes of converting it? what type of horse power and psi should I look for? Are electric types a viable option? I would be using it for residential mains mostly and the majority of the lines here are cast or abs. Thanks in advance for your input.
    Re: Best pressure washer for conversion
    tungstun, welcome to the forum
    an electric would be useless for your application. unless all you want to do is 1.5'' and 2 '' kitchen lines from indoors. 2 hp motor will trip most breakers under load.
    a good starter unit for most is 13hp 3000psi @ 4gpm. with the right nozzle/ root ranger, it will cut roots pretty fast when it's properly aimed at them. a camera makes it easy to do that.
    the major difference between a pressure washer and a jetter other than the hoses and nozzles is the pulsation valve. a good foot operated safety valve will do almost as good as a pulsate valve. a foot valve is a safety must and allows you to control the water and keep both hands free for working the hose. a spray gun can be used, but it takes 1 free hand to operate it. a pulsation valve can be added to most pumps.
    read the drain cleaning section as there has been dozens and dozens of jetter related topics posted there.
      Thanks for your reply. I actually just searched the forum and discovered a ton of information. So a electric washer would be an option for indoor applications? And how would I get around the whole tripping breakers problem?
        For my electric jetter that draws 20 amps this is a problem for me too.
        But I quickly solved this problem with a 20 amp converter. It plugs into drier outlets or stove outlets Many homes up here don't have the 20amp
        outlet required for most electric jetters
        Here is a picture of the converter it's by Mytee a cleaning industrial company.
        The electric jetters are good for small drains. most off the shelf pressure washers lack pulse action like Rick said and don't have a higher GPM like sewer jetters.
        Rod
        http://unclognh.com
          Could you suggest an option thats not too expensive. Im newly licensed and capital is kind of tight right now but I want to be able to give my customers the option of jetting as well as cabling. I have all general drain cleaning equipment now a speed rooter 91, a mini rooter and a power vee with a stand for the small lines. I like the design of the ridgid machines but I was able to get these at a great price.
            My electric jetter is from watercannon
            here's a link Had my for 4 years now no problems
            http://www.watercannon.com/pc-548-6-...-ej2015-g.aspx
            Rod
            http://unclognh.com
