Ridgid weld on repair end
  • Ridgid weld on repair end
    Was thinking of brazing the cable end inside the cavity. before I weld it on,any thoughts?
    Just what role does the cable play ? Thanks
    Re: Ridgid weld on repair end
    tool, brazing is going to be a long heat cycle and ruin the heat treating of the cable. where the weld is quick and only at the end. this is there to keep it from unscrewing.
    i wouldn't do it
      Tool Are we talking about the General cable? If we are it is not really a repair cable without welding a coupler on the outside, you cant dig out the cable like you can on others and put a screw style coupler or end on it the metal just won't take it.
      Seattle Drain Service
