Innercore wire
  • Innercore wire
    Does it float with No attachment at either end ? Is it full length or a little less ?
    Re: Innercore wire
    Depends on the cable and type of inner core. most 3/4" cables it just floats and gives the cable something to torque down on. the Magnum cables .55 and .66 the inner core cable is attached to each end, and when the cable torques up the inner core which is a opposite wound cable tries to unwind as the duel outer cables tighten, which makes the cable get stiffer faster as well builds torque quicker. This is why you can only buy the .66 and .55 cables in 50' lengths or less. Eel cable has the inner core cable attached at the ends to help maintain stiffness of the sectional cable.
    I hope this response was clear enough and helped.
      Re: Innercore wire I keep learning
      Thanks ,Your Knowledge is impressive. Welded the I.C. to one end doing a repair. Mistake. After loading about 40' of 100
      It got rod like. I grabbed the loose end and snapped the weld inside. All is well and fixed
      Proper. It sure was funny at the time.
        I got a laugh...till my side started to hurt
          Re: Innercore wire
          Good, We all need to laugh these days. The 3/8" Got progressively harder to load in the drum. Then I lifted about 15 ' straight out like a giant Hard on! Wow Mama!
