private label drain cleaner
  • private label drain cleaner
    just thumbing through owners manuals and i stumbled across this roto rooter 5000 machine. sure looks like the k-3800
    http://ridgid.com/ASSETS/1ED20205B15...achine_Man.pdf
    how do i get a rick-60 private labeled
    Re: private label drain cleaner
    You do something to deserve it!
      Speaking of Roto Rooter, anyone catch the "Undercover Boss" episode with their COO/President last week?
      I thought is was totally scripted. Especially the American flag bandanas at the Iowa plant and the "we're staying here in the USA" tag about the manufacturing.
      I also liked the guy rodding on the roof with the 7500 sitting on the ground and running a cable up the ladder!
      ...And the "towel in the drain" that looked curiously like the rag the guy used to block the overflow of the tub
      -Chris
        GUESS WHAT RICK YOU ARE CORRECT !
        I WORKED FOR ROTO ROOTER IN THE EARLY 2000'S
        AND THAT IS THE EQUIPMENT WE USED WITH A ROLL
        AROUND HANDLE SETUP
        SOME TRUCKS AND TECH'S USED THE STANDARD R.R.
        STYLE MACHINES AND ME AND THE REST USED THE
        RIDGID LINE UP WITH THE DRUMS EMBOSSED
        WITH THE ROTO ROOTER NAME !
        THEY HAVE SINCE CAME OUT WITH OWN LINE OF
        RIDGID STYLE MACHINES
        JERRYMAC
        E-MAILJERRYMAC777@GMAIL.COM
        FIRE SPRINKLER CONTRACTOR,
        SINCE JAN. 1989
          Oh those things When I used to work for RR
          They brought those out in 1997-1998 JUNK They took all our Vikings away
          and replaced them with those. All the techs including myself booted them off our vans within a week. Went back to Vikings
          Rod
          http://unclognh.com
            Good one!
            Though I think Rick may have sold more K-60's then any other company Ridgid Sells through.
            Of course with Josh by his side taking all those pictures of the machine in use it makes it easier...
              -Chris
              You are singing my song Chris.
              If you use the forum search function you'll actually find some Rooter lover's that say the rag is real.
              Member "Papadan" started another undercover rooter boss thread on the day of.
              Got alot of attention.
              Sheck it out
                -Chris
                We used to use the machine on the ground going up a ladder back in the day. It had a pipe hooked to the top ring so it wouldn't rub against the last step or the customers roof. We had one guy on the ground and one guy on the roof telling him what to do. That was until we got more machines that we could actually carry up the ladder.
                  I've done it. It sucks!
                  www.ClinkscalesSeptic.com
                    I have run the old old R.R. and Spartan 1065 from the roof
                    by myself many times !
                    on the Spartan i would take the special hubbell female plug off
                    the electric foot-pedal and put it on a g/d pigtail so i could
                    plug into the machine then use a 25' ext. cord run up
                    onto the roof a second 50' or 75' ext. cord from inside
                    the house up on the roof for power that way i had the
                    foot-pedal on the roof with me put the power feed on
                    a slow forward speed and run the cable all the way 125'
                    get down and check house then use power feed in
                    reverse while i was on roof pulling cable back from vent
                    i could run it in and out as many times as i wanted then
                    pack up and go to next job,
                    but when i ran by own co. in L. A. I would all ways have
                    two men and charge for them would not let any my guys
                    run from roof by them selves for ins. and liability reasons
                    JERRYMAC
                    SINCE JAN. 1989
                      In my younger and dumber days I did a lot of that by myself. The model N Eel was good to take up a roof I just unscrewed the drum and took it up one piece at a time then put it back together on the roof (for sink drains only) Also stood on a few ladders with the machine on the ground and The cable would always catch my pant leg, I am glad they came out with them hand gun machines. I was lucky except for one time, it was winter and I had my winter beard and the cable cough my beard and stuck my nose in the drain before I could stop it. My customer came down and asked what I was doing I told him I was smelling for sewer gas that is a sure sign the pipe is open! After he left I took my pocket knife and cut my beard off to get out.
                        caught that on t.v. My favorite part was the air ram
