Ice Jetting woes
    Re: Ice Jetting woes
    A good trick for getting started backwards in a san t is:
    - bend the end of the hose back on itself so it makes a 180 with the last 4"-6" pointed back at you.
    - push the loop into the cleanout, so the hose goes down into the c/o, does a 180, and the nozzle points back up out of the c/o at you.
    - arrange the loop so the side of the c/o that the nozzle is on is the way you want the nozzle to go
    - push down on the loop with a long skinny something, feeding hose in as you push down, so the nozzle travels down the c/o still pointed back up
    - when you get the loop to the bottom, move your long skinny something over and up a little and push the nozzle down the last bit
    - when the nozzle clears the lip of the san-t, it will flop into the line pointed the right way.
    - now don't mess with it; just start up the machine. if the nozzle doesn't pull in, pull just an inch or so of hose back out, then feed back in
    - usually works, sometimes takes a few tries, especially if it's a deep c/o.
    For a cable, I use a short leader whip with a 45 degree kink about 2" from the end.
      I can see the bucket head vac would be extra nice for when you are lucky enough to have a helper to haul one bucket while you fill the next.
        Sometimes I alternate between 2 buckets... or fill 2 and have a balanced load
          Your suggestion for the hose is pretty similar to what i've tried.
          I haven't had alot of luck, but I haven't really tried it very much.
          I'm gonna try it again, with my newfound support of someone else who had made it work
            I got it open!!!!!!!!!!!!!
            There's still a partial obstruction, but he says he's just gonna dig it in a few weeks (he owns a dirt business).
            now i'm lookin online at some new nozzles
              Just in time for spring, I recycled a Lennox boiler for on site unlimited hot water for jetting frozen pipes. I just opened one last week with the HO's hot water. I think that I will not see too many frozen lines this year. Spring is coming a little early this year although we are expecting snow tomorrow.
              Ace will you be skiing till July this year at A Basin?
                I lost interest in skiing years ago. Got out bouldering Monday, threatening to break a bicycle out today. Need a new winter sport.
                Not a huge pack this year, doubt lift served will last 'til July, though you can always hike.
