4 gpm jetter for 4" ?
  • 4 gpm jetter for 4" ?
    Yes...I know that the subject has been killed already but I just want a simple answer to my simple question. My buddy already has the reel set-ups for a jetter but is contemplating which jetter to buy. I can get a 4200 psi/4 gpm Honda/Cat pressure washer for $1,000 brand new. Is this sufficient for 4" lines(primarily grease)? This will be my first jetter and I really didn't want to spend $6,000 for a 18hp/6 gpm set-up just yet......
    Re: 4 gpm jetter for 4" ?
    good for 4'' grease with the proper nozzles and hoses, but 13 hp honda won't put out 4200# at 4gpm. 16 hp will.
    $1000 is very cheap.
      It'll work. Won't be a no brainer couple of passes deal; you'll have to be intelligent and thoruogh, making mulitiple passes nice and slow.
      I'd say just get the bigger one as you will anyway, but $1k is pretty cheap.
      I'd think you could get 5.5gpm/4kpsi in the $2-3k range if you really wanted to and were willing to put the time into it; buy an engine and bolt ar's direct drive 5.5gpm pump to it, build your own frame (assuming you have a welder) or buy one from one of the pw companies if you don't.
        So are AR's pumps just as good as Cat's....any major differences? Also, if I build a 24hp/8 gpm unit...can I lower the gpm if I don't need it for the specific job and don't want to set up a reserve tank? Thanks.
          Cat used to be the good pumps but they have fallen a little they didn't keep up with the times. A/R are a middle of the road pump, I like Udor pumps, 2nd choice A/R third choice Cat. General pumps blow up pretty easy if used a lot.
          You can turn your RPM's down but pressure will drop also. But to save space you could use a 100 gallon tank and will need to take breaks.
          Seattle Drain Service
            That's It!!!...I'd gonna bulid one finally!!! Is a 24hp Honda engine powerful enough to push 8 gpm at 3000psi? Is 3000psi enough pressure for most lines up to 6" at that gpm?
              yes 24hp will do 3000psi at 8 gpm and 3000 psi is a good pressure.
                Do you know of the Udor pump model number that I should be using with that 24 hp? Besides that...I would need an unloader valve, cart, gauge, reel with hose...what else? I appreciate all your help.
                  Here is a link
                  http://www.pagegangster.com/p/HarDl/184/
                  Udor Gear reduction model GC-30/17-GR
                    What has CAT done to not keep up with the times?
                    Thanks.
                      Bump. I need to know.
                      Thanks.
                        Thanks.
                        Why?
                          Why?
                          I have a CAT Pump spec'd for a job and I don't like to do things twice.
                          Thanks for any help.
                            What I meant was they where the leader the pump with 9 lives, the closet competion then had was General. There pump designs didn't change remained large, stayed with there high prices, Udor came along with new triplex designs, with a lower cost and bumped them out of first.
                              So if I understand you correctly, they still make quality, but now Udor can offer similar quality at a lesser cost depending on what you need.
                              Sound right?
                              Thanks.
                              (I checked CAT, AR, Giant, and General for the job. I looked at Udor but not into great detail. Seems I couldn't find distribution and parts in my area if I recall.)
