Paint prep for my jetter.
  • Paint prep for my jetter.
    Paint prep
    5 hours to take the tin off and remove all the gauges and wiring.
    The tin is out being sandblasted today. I will be painting it safety red to match my step van
    paint will be ZERO-RUST
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: Paint prep for my jetter.
    Looking forward to seeing the finished product!
    Have you scored any municipal contracts?
      I’m not looking for municipal contracts. More commercial and farm use
      Appleton WI, 54915
      1-920-284-7471
        got it. That's a monster machine. Looks like the baby brother of a combo jet vac truck
          Pretty close. I am putting an extra hose real on it to run ½ hose.
          Appleton WI, 54915
          1-920-284-7471
            That is what I call a jetter!
            You're going to put the output of THAT into a 1/2" line? Egads.
              No not all. I am putting on a separate valuing system to put 20 GPM in the ½ hose and divert the rest back to the tank.
              Appleton WI, 54915
              1-920-284-7471
                blasted and ready 4 paint
                Appleton WI, 54915
                1-920-284-7471
                  Sand blasting is the way to go with old metal like that. I've blasted some old trucks and tanks that we re-furbished. The actual blasting process is a nasty job, I hope you didn't have to do that yourself.
                  Looking good though!
                  www.ClinkscalesSeptic.com
                    now i had it done.
                    Appleton WI, 54915
                    1-920-284-7471
                      What's the specs on that jetter?
                        65 gpm 2000 psi
                        Appleton WI, 54915
                        1-920-284-7471
                          steel is all painted
                          Appleton WI, 54915
                          1-920-284-7471
                            all painted and ready to GO. i just need to re do the running lights
                            Appleton WI, 54915
                            1-920-284-7471
                              beore and after
                              Appleton WI, 54915
                              1-920-284-7471
