Jetter Float valve and tank?
  • Jetter Float valve and tank?
    How do you guys set up the fill valve in the surge tank? I can't find a source for the tanks that you see on General's machines. Does it just fit stragiht down inside of it?
    Re: Jetter Float valve and tank?
    http://www.pressuretek.com/floatvalves1.html
    Hope this help
      How about an ENGINE THROTTLE DOWN switch, should I install one on my jetter? ( I would have to get the Allison soft-load unloader with the micro switch.)
        i was looking into that unloader with the throttle down. but with jetting, i doubt there will be much fuel and wear and tear savings as compared to pressure washing with a spray wand.
