How Would You?
  • How Would You?
    I have been doing alot more work for smaller resteraunts. i would like to get them set up on a preventative maintenance contracts but I have no clue how to even start with one. How do you guys charge per lateral? or how much time you think its going to take you? what are your selling points? I want to make it attractive to the owners I want them to be able to save money but I would like to make money. Any tips would be appreciated
    Thanks
    Mike
    www.plumbinginclarkcounty.com
    Re: How Would You?
    offer an enzyme treatment package. an enzyme injector into the trap. if there is a blockage related to the trap then you eat a cleaning. if it's something else (scrubbies, plastic, straws, big food bits, broken glass, etc) you charge for a normal cleaning
    there is a company here that does grease trap maintenance. if there is an issue that is beyond the scope of the trap then i get the call and charge for a normal cleaning. win-win-win for everybody involved
    steve
      Re: How Would You?
      Thanks
      I think the first question is what services are you willing to provide? That depends on the frequency of the visits. Plumbing only maybe every 4 to 6 months. Gas fired restaurant equipment...1 hour every month minimum depending on equipment.
        Re: How Would You?
        Thanks
        As a consumer I would expect some discounted rates over normal type calls.
        Reason being is it's preventative maintenance. Preventative maintenance should give you better conditions to work with as lines may be only a little slow, but could use some attention.
        You would have to justify what the rate should be based on your numbers.
        Plus it gives you guaranteed revenue and possibly could lead to other work.
        Selling point to a business?
        You could emphasize no downtime or emergency calls to an owner from a manager.
        Cleaner conditions leading to better ratings from Health Department leading to more customers & income for their business.
        Off the top of my head.
          Re: How Would You?
          steve
          Be carefull with this. Some cities don't allow enzyme systems. They say the grease simply moves further downstream before it solidifies causing the main to plug.
          www.ClinkscalesSeptic.com
            Re: How Would You?
            Leave out the word "preventative". Just call it a maintenance plan!
            If that baby backs up one time on your "preventative" plan they are going to be mad!
              Re: How Would You?
              JH hit a bullseye with that last comment. Seen a former boss get burned because he was doing "preventitave maintance".
                Re: How Would You?
                Selling points:
                - pm work will decrease (not necesarrily eliminate) unscheduled drain work, reducing downtime and unbudgeted expenses
                - pm can be scheduled, allowing work to be done at times of minimal impact to business and allowing costs to be budgeted
                - pm work can be done at a reduced cost because it is easier for you
                - it is non-emergency so it can be done when you have a slow day, and if you get an emer call you can break off and come back with little impact to pm customer
                - you can do it at times when you don't have to trip over employees and they aren't tripping over you, and you are not running sewer lines in a kitchen at the same time they are serving food; good for everyone.
                - nothing is actively backed up, so you can jet w/o flooding issues
                - it is being regularly maintained, so when you see it it is not packed from end to end taking more time to get back to clean.
                - they may end up paying for some pm work they didn't need just then, but it ends up being about the same because if they wait until it backs up they have a mess, downtime, and more cost in that job because the line is way dirtier and there flood management issues with jetting so it takes longer to do right.
                pm programs are good for the kitchen manager, and good for the drain cleaner. budgetable, schedulable, predictable, hassles eliminated on both ends.
                emphasize that pm is not 100% insurance against clogging/backups. it will reduce or eliminate problems from buildup over time from normal usage, but you cannot guard against events of abuse like objects or whole pots of pasta or grease getting dumped.
                  Re: How Would You?
                  The only problem I had was they wanted it done after they closed at night. This made for a lot of midnight calls for inside drilling. Out side drains I could do most any time at restaurants. Factory's Were after 5:30 PM. But it was good steady work till some chain bought them out and they already had a maintainens co. that did all the maintence work, elect, plumb,building repair. stopped in and talked and gave cards and got all the emergency calls.More midnight work.
                    Re: How Would You?
                    I've had problems with people sticking with the program. Charge normal rates if they fall too far behind. I will onlyl pm a whole place to easy to have other issues only doing half the place.
