Buggar It
  • Buggar It
    I been clearing sewers for forever but today with my K1500 I lost a cable trying to get in out I put the camera down after clearing the water from the blockage and thought yes I could clear it even better when I should have left well enough alone so I feed two cables down with the thinner leader to get around the 100mm PVC trap with a 75mm sharktooth cutter and no matter what I did in forward or resverse I couldn't get it our a clump of roots had grabbed the cutter or cable which I carn;t fathom and one of the cable connector came apart and that was it a sawtooth cutter leader and one cable stuck halfway in the main sewer and halfway in the customers sewers I could push the cable forward but not out and this hasn't happened for at least five years and the last time by thinest root you could imagine why???????
    Tony
    Re: Buggar It
    the only way it came apart was if the pin detent unhooked. a weak or broken detent spring most likely.
    are you able to try cutting the roots out with another cable/ cutter to free up the caught one?
    can a jetter help cut it loose?
      Re: Buggar It
      I feel Your pain! At least it's not Canada where You have to dig 5' in frost! RIGHT ?
        Re: Buggar It
        No Rick the whole coupling came off one of the cables as I forwarded and reversed the cable tyring to get it out.
        Tony
          Re: Buggar It
          Yea I agree with Rick send another cutter down with a arrow or split a 4 blade cutter and take a few of those roots off. I never had that type of cable tangle together when run side by side.
            Re: Buggar It
            I do not envy you having to deal with those traps at the property line... I forget what you call them. Seems like if they are going to do that they should also require an access for them at the surface.
            Nothing like getting stuck and losing equipment to ruin your day.
              Re: Buggar It
              On the older properties the sewerage pipes from a building flow into a boundary trap and then into the authorities sewerage pipe, the boundary trap can be at any depth but a shaft extendes to ground level from them for venting and to gain access and now I am waiting for them to retreve my cable as their sewerage pipes have colasped and will need to be renewed.
              Tony
                Re: Buggar It
                I have used the hook shape on the Root Ranger to drag cables back for plumbers in the past!
                Regards, Bill
                The definition of Insanity: "Doing the same thing over and over expecting a different result."
                Albert Einstein
                  Re: Buggar It
                  I actually pulled apart the whole coupling from one of the cables so you can imagine the force involved while trying to get it out no the only way is to dig.
                  Tony
