Mini Rooter problems
  • Mini Rooter problems
    Greetings all,
    First time poster and just starting viewing this forum on Saturday.
    I purchased a General Mini-Rooter with 3/8"and 1/4" drums and have been dissapointed in it's performance.
    The last three jobs I have done all being from roof on a 2" cast iron kitchen stack it seems this machine with 3/8" cable cannot get thru clogs and I am quite certain it is at the bandboard offset.
    This machine was recommended by local distributor.
    I am thinking of trading it in for a new machine (s).
    Re: Mini Rooter problems
    rr. good move. rick jawed me into a k-60. haven't looked back. rick photographs very well. do a search you will find several smiling ricks with a k-60 on roofs. breid...........
      Thanks breid .........goin there now......
        for 2'' you'll need the 5/8'' sectional cable and either a 4 blade cutter or the auger.
        the k-50 is more like the mini rooter in capacity. but the k-60 is the best of both worlds as it will do the small and the large stuff, plus roots.
        unfortunately the k-60 will set you back 4 times the cost of the mini rooter, but well worth it.
        i know adam smiles every time he uses the k-60, he calls me
          the k-60is a good suggestion... I wish I had one myself
          the mini-rooter will take up to 1/2" cable
          I have decent luck with mine using 1/2" cable
          Keep in mind, it's only a 1/3 HP motor
            Originally posted by RunRiser View Post
            Greetings all,
            I have used this machine on sinks and small drains several times and kinda like it
              what cable/ accessories would you recommend for the K-60 ?
              thanks for the quick responses guys
                i don't call rick, but i certainly thank him. breid..............
