3 1/2" Cleanout Plugs......
  • 3 1/2" Cleanout Plugs......
    These are the most common size in my area. Why is it that nobody seems to carry them and if they do they are they slotted type. I can't even find them for a descent price online
    Re: 3 1/2" Cleanout Plugs......
    I know. I get the Cherne gripper in 3 1/2. It works well. Only one supply house in town has got them and they cost an arm and a leg. It seems that the threads on 3 1/2 are always junk too. Those drum trap style c/o are always a pain too. Hard to find replacement that seal desent.
      Goto Hodes Co website. http://www.hodesco.com and in the product search search these Item codes out with out the text.
      • 90-592 gripper Plug 3 ½"
      • 70-414 slotted plastic plug 3 ½"
      • 70-310 counter sunk brass plug 3 ½"
      • 70-304 square head brass plug 3 ½"
      We been buying from Hodes for years. The product they carry is quality and we have been real happy with it. The brass plugs is real brass not that die-cast crap.
      If you are looking for good 17 Gauge p traps they have the best with the good brass hex nuts as well
      • 50-508 Ptrap 1 ½" 17 Guage
      • 50-504 P trap 1¼" 17 guage
        I'm looking for the 3 1/2" square head PVC/plastic plugs.
          Sorry never seen a 3½" plastic plug in a square head. Only the slotted ones as I posted the item #.
            No need to be sorry That's exactly what I'm talking about, they can't be found and when I did find some they wanted like $8.50 each
              Just found some for $5.60 each. Still too much for a plastic plug lol Why is it that the 3 1/2" is so much more than the other sizes
              http://www.plumbingsupply.com/cleanoutplugs.html
                same thing here, you have to use ABS and at a cost of 5-8.00 a crack. when i see them on sale i buy them all. but i am now all out...
                Sent From The StoolBus
                www.appletondrainandsewer.com
                Appleton WI, 54915
                1-920-284-7471
                  I've never seen a 3-1/2" plastic plug. I use brass plugs for 3-1/2" cleanouts (Which are very common in my area).
                  3-1/2" is not a standard PVC size. I think that's why A) they're so hard to find and B) so flippin expensive if you can find them.
                  There are some "econo" or twist style plugs out there that work for 3-1/2". I keep a couple on the truck too.
                  Maybe all us midwesterners should just petition Charlotte Pipe
                    Same here I keep 3-1/2 brass stocked in the van and a few 3-1/2 fit-all's
                    Rod
                    http://unclognh.com
                      3-1/2" plastic plugs are almost standard here just purchased 10 a few days ago. The cost was about $3.50 each. Every supply house in town has them.
                        Do any of them do mail order ?
                          Pm me your info I'll get you a truckfull or whatever many you want.
                            3.5'' is the standard for a 4'' ibco. i have brass and abs in flush/ slotted and raised/ square head. they do cost more as they are more of a specialty fitting than a standard size.
                            wait till you need a 3.5'' gal nipple and see the price
                              Really,The counterperson looked at me like I was crazy when I ordered a 3.5x6 nipple for chasing threads.
                              I can't wait to get back over there tommorrow morning.
