What size jetter battery????
  • What size jetter battery????
    I am finally done with the belt driven 24 HP Honda jetter that I built. What size battery should I use? Honda recommends a 36 AH...but i can't even find that spec on the batteries. Should I just get one that they use in compact cars...or is a lawn tractor battery enough?
    Re: What size jetter battery????
    Pics please!!!
      i use the lawn tractor style. i believe you have a 20-25 amp charging circuit on that honda.
      as long as you don't have back pressure, the starter will spin just fine.
        I had a riding lawnmower battery at first then switched to a very small car battery and have been happy with the dependability. My jetter does not get used everyday and it seemed to bridge the gap for it always being ready to go. I keep a portable battery charger with jump start setting in the van just in case. And yes I have had to jump my jetter off the van battery before I bought the bigger battery.
        Seattle Drain Service
