Engine terminator wiring?
  • Engine terminator wiring?
    I am at the very end of wiring my jetter. To which wires do I hook up the black and white wires coming out of the engine terminator? Thanks.
    Re: Engine terminator wiring?
    i believe it's a ground wire kill switch. so the easiest is to connect to the low oil switch/ piggyback it. and the other to ground.
    double check it's a ground wire.
    check your wiring schematic for sure.
