K1500 using electric eel cable
  • K1500 using electric eel cable
    Has anybody tried the Electric Eel 1 1/4" model C (inner core) or General (chain core) cable in a K1500. Seems it would be great. Would make the cable self-feeding yet stronger and have the most torque to get free when stuck. The C cable is ran in reverse going in & forward coming out. As you guys know I'm not a big fan of running the K1500 cable in reverse.
    Best, Dennis....
    Re: K1500 using electric eel cable
    EEL cable's are all I ever run in mine. But I never put the machine in reverse to put them in, the Ridgid spins so fast that you don't need to except starting through a trap. I keep it in the same direction going in as I do coming out If you pick up a big wad of roots and change directions you can get hung coming out. I keep an EEL C at the shop and If I do get hung I can hook up the EEL tighten the clutch and pull it out The EEL turns slower but has more power I use it to get out other guy's cable.
      I have a old K500 with 4HP gas engine and transmission. It's like new since it hardly gets used. I've been thinking about putting a 4 or 5hp electric motor on it for just what you said, getting a cable free.
      Thanks, Dennis....
        Thanks, Dennis....
        good luck. a 2hp. motor is as big as you can plug in. plus a 2hp. electric will out do a 4 hp. gas.
        all you need is a timberwolf drill. it will wind a cable up like a pretzel if necessary. but you keep tension on the cable and work it loose.
          I know that's true but had a dumb attack anyway.
            Rick, have you been wearing your underpants on the outside.
            How strong are you, if mine starts getting over torqued I stop the drill and remove it and have another go.
            I don't want to look like a cartoon character getting flung around in mid air.
            Simon
              Sorry D I think I just accidentally hijacked my first post.
