Two nice blockages.
  • Two nice blockages.
    Got a little busy today. Picked up a backed up master shower , and a main line where the guy hired two other plumbers and they couldn't get the line open. Here are pictures of the blockages on the different cables.
    Re: Two nice blockages.
    Nice work; always nice to succeed where others have failed.
    My first thought on the shower drain was wow, that's a beefy cable for a shower. But looking closer I see it's a pretty open wind, probably real flexible. What kind of cable is that? looks almost like a sectional cable in a drum?
      Yep open wind 5' sections in a drum. Its the Eel Model N They call the cable 5/8 duelmatic cable. It will do 1 1/4 to 3" lines even though I have done a few 4" lines with it with no issues.
        Nice pics.......How do you like your new machine?!?
          It has been performing flawlessy. I use it more than my K-50 and spartan 100 now.
            Always enjoy reading and seeing your post Ron.
            What application would you not use the Model N and instead use the K-50 or 100 ?
              Well if I needed smaller cable like a pistol rod sized cable I run the K-50 with the drum attachment. As for the K-50 and 5/8" cable I would run it if my Model N was either broke... If Ridgid came up with a drum type machine that ran the 5/8" k-50 open wound cables I would be all over that. It keeps the mess self contained. And if I have to run the Model N in the same line I can quickly remove the drum take it outside and hose off the cables.
              As for the Spartan 100 I keep it on the truck as an alternative machine, kind of like the K-50 as well. If for some reason the Model N can not make its way through a blockage, the different style cable (13/32 with one heck of a bend on the bulb where the cutter attach's) of the 100 might be able to torque through, or the speed or cutter selection of the K-50. Oh another advantage of the K-50 is the washing machine gray boxes. You can set the K-50 on a rag on top of the washing machine to get close to the gray box. So that is defiantly a job I would use the K-50 on.
              As I have always have said, each machine has its place to be used. It all depends on the circumstances and type of blockage I am dealing with.
                +1
                It's just that some machines are better at more things than others
                  I did not get to take more pics of each job. But I ran both rods back in. On the shower line I ended pulling out a little more hair. But on the main, I ran a 3" 4" and the expanding 4x6" cutter. I ended up pulling out a 5 gallon bucket full of roots in all.
                  I wish I had a photographer like Plumber Rick Maybe this week I will get some good snap shots of me working. My daughter is home on summer break so she wants to earn a few bucks working with me. Who knows maybe you all get to see her man handling the K-1500 again.
                      I need to start bringing my camera, I had a hair ball that was 2"x24" on a shower drain.
                      Nice job.
                        Nice pictures Ron
                        Rod
                        http://unclognh.com
                          I just realized this kind of stuff is plumbers porn. Just showed these pics to a non-plumber friend, and he was all eww gross.
                            Isn't that the truth
                              I just missed a photo op of my daughter rodding a floor drain today at a Ruby Tuesdays. She was all into clearing the stopage, and running a new machine. (new to her)
