Best Cutter For Soft Grease Blockages....
    Re: Best Cutter For Soft Grease Blockages....
    Mate, get a jetter! We use 'Grease Release' and we import it from the US. It solidifies the grease and makes it float out to the trap instead of closing over the blade or nozzle. Hot water also helps above 65deg.C.
    Regards, Bill
    The definition of Insanity: "Doing the same thing over and over expecting a different result."
    Albert Einstein
      at
      i take mine to car wash. wash then use the wax. breid...................
        Originally posted by SewerRatz View Post
        Augers work well in helping to stir up the grease. There are times I find duct taping a rag to the 3" cutter where you have two tufts of the rag sticking out each end that exceeds the diamtor of the pipe by an inch or so. This scours the pipe and helps push the blockage.
        If the above does not work I fire up my small electric jetter. Which is very rare.
        Next time this happens I'm going to try the rag trick
          Make sure you tape it on good. You do not want to lose your rag in the sewer.
            Originally posted by sewerratz View Post
            make sure you tape it on good. You do not want to lose your rag in the sewer.
            lmao
              A 3000 Ridgid Jetter
              You can lose with me, but you can't win without me!.... PPI
