Clean Out Plug Wrench Kit...
  • Clean Out Plug Wrench Kit...
    Anyone have any thoughts on this kit at $189.00 ???
    http://www.faucetdepot.com/faucetdep...LAID=361932019
    Re: Clean Out Plug Wrench Kit...
    It is a really nice set when you have a plug which is hard to get out. However, for the other 90% of the time you will use channel-locks.
    Check with jerrymac if you are interested as he was selling a demo set.
      Jerrymac has one. It is a good set to have but don't use it very much
      When I need it I'm glad I have it.
      Rod
      http://unclognh.com
        yes it is a very good set,
        and the time i find it most useful is when you have a clean plug
        recessed into the floor or wall where you not get a pair of
        channel locks or a pipe wrench to fit !
        BY THE WAY MINE IS FOR SALE IF ANYONE IS INTERESTED ! P.M. ME
        JERRYMAC
        E-MAILJERRYMAC777@GMAIL.COM
        FIRE SPRINKLER CONTRACTOR,
        SINCE JAN. 1989
          i've had my set for well over 10 years and although i only use a few sizes, it's a lifesaver. i also have the pipe wrench to go with the set.
            I also have the pipe wrench, the corporate stop, extra extension and an adapter for my Milwaukee cordless impact driver.
              Hey Mark, I've got that set also very handy when you need it. Did you make the impact adapter yourself?? Sounds like a good thing to have.
              wookie
                wookie
                The adapter is just a 1/2" X 3/4" socket adapter. I only use it when I have a ton of 1 1/2" and 2" drains to inspect.
                  HEY WOOKIE!!! Nice to see you on!
                    Nice to be seen Back at you!
                    wookie
