Cleanout Plug Wrenches ???
  • Cleanout Plug Wrenches ???
    Anyone ever have to use one of these on a cleanout plug ? Should I keep them in the van ?
    Pin spread measures at 3 5/8" & 4 5/8".
    Re: Cleanout Plug Wrenches ???
    Never seen those kind before
    Seattle Drain Service
      Where are you really going to use these ?
        Uhm... that's what I was asking
          I would not waste the space . But then again I only have a 8 foot utility body truck.
            I've never seen that type before.
            I have a 4 spoked key that fits recessed CO plugs. Lets you get a wrench on it.
            But if it's an old plug and has never been off before, I usually end up having to hack or drill it out. Cast iron plugs are especially fun
            I don't think I'd ever have a use for those.
            Just my 2 cents
            -Chris
              I think you just answerd your own question no I dont see a need
              SMELLS LIKE $$$$$$ TO ME
                Looks like it is missing the Handel or maybe an impact adaptor I have never seen one I use a multi. spud wrench my self with PB Max. But I would like something with an impact wrench I could put on. Maybe that was made for an adaptor.
                  if a wrench won't get them off I just chip them out of the way.
                    Sometimes that's next to impossible
                      I keep a 3/4" 12pt socket set on the van. Will get most raised square head ones. Welded a piece of flat steel to a big nut for those ones with the slot. Hammer and cold chisel for the rest.
                        I used to use a chisel but now I use a makita 4" grinder with cheap diamond blade and cut to near the threads, it just pops out, real fast.
                          I ended up not putting them on the van. Had a call yesterday at a former Sentry super market and could have used the larger one on a gray plastic cleanout plug in the mens can.
                          I know I'll never see another as long as I live but I'm putting them in the van
                            I think they would be more effective than than what I use. The back of a crescent wrench turning it with channel locks. Of course the hammer and chisel after that fails.
                            Is that something ridgid sells?
                            I don't need it often so I always forget to look for something like that. I would definitely keep that on my van.
