Maintenance
  • Maintenance
    What drain machine's do you primarily use? Ridgid, Electric Eel, Spartan, General, Gorlitz, Mytana, Rothenberger etc.
    Specific Models?
    (I do know many that some use. But it's a good reminder and education for me. Thanks.)
    How often do they get used? Example:
    "My K-60 gets used 400 times annually. My K-39 gets used 150 times annually."
    What specific maintenance are you having to do on your primary machines?
    At what intervals?
    Thanks for all input.
    Re: Maintenance
    We have ...
    2 - K-50's - used approx. 50 Times a year
    1 - K-1500 - Used approx. 10 times a year
    1 - General Speedrooter 92 (I hate it) - used twice since we bought it 1.5 years ago.
    As far a maintenance goes..I just pressure wash the cables down and scrub them with a hard bristle brush. For the smaller cable in the K-50 I'll use WD-40 when I'm done cleaning.
    We don't do much drain cleaning.
      Re: Maintenance
      Why do you dislike the General so much?
      Thanks.
        Re: Maintenance
        Anyone else? No maintenance?
          Re: Maintenance
          I run Electric Eel
          My Model N gets out about 325 times a year ...
          I Replace about 60 ft of cable each year
          My Model D gets out 200 times a season
          Change the power feed bearings each year cable has been changed once in 8 years
            Re: Maintenance
            DM-55 grease and lube every 30 day's Over kill but machine will last for a 100 years. Lube cables after every job. Keep machines clean check wires for splits or cracks. other machines grease and lubed every 6 months.
            Rod
            http://unclognh.com
              Re: Maintenance
              K-60 (the workhorse) gets used about 4-8 times a week
              K-50 with 5/8" cable or drum adapter gets used about 4-8 times also
              The eel model c maybe a hand full of times a month, just on the really nasty root job.
              The k-7500 sits on the van and is jealous of the k-60! I only use it maybe once a month, that might even be a stretch. It does look nice on the van. I use Ridgid snake oil on the cable after ever cleaning.
              I power wash and snake oil sectional cables about 3 times a year, i used to do it more just to damn busy to do it. I do WD 40 the connectors on each job. I take apart grease and clean the k-60 and k-50 twice a year.
                Re: Maintenance
                Seems everyone doesn't have much maintenance at all as long as they go with a professional brand.
                Thanks.
                  Re: Maintenance
                  Thanks.
                  I do what others have taught me here.
                  The K-7500 only gets moved when it's time to do the bi-annual garage cleaning.
                  K-60:Wd-40 ends.
                  K-39:Pull the cable after every use.Clean the can occasionally(Thanks Rick)
                  KJ-3000:Run motor every couple months while spraying off a bad sewer job on cables.
                    Re: Maintenance
                    I use all Spartan machines. The 2001 i grease the bearings on the feeder every 3 months, oil the cable every month. the 81 i just oil the cable and loosen and tighten bolts so they dont get rusty get stuck. The 100 i oil the cable and grease loosen and tighten bolts so they dont rust. thats about it.
                      Re: Maintenance
                      I primarily use my trusty Edith. Take her out of the bucket and plug her in, and she's good to go.
                      I did use her for actual drilling, for the first time the other day. I don't think she liked it. I think she feels she's above that now
                        Re: Maintenance
                        K7500 15-25 times a week, clean machine and oil cable after every use,
                        K750 5-6 times a week, clean machine and oil cable after every use
                        K39 and K39AF 10-20 times a week, clean machine and pull out cable after every use.
                        K-60 2 times a year same as above
                        K3800 5 times a week clean machine and oil cable after every use
                        K380 only when I have to. It a piece of junk, I done clean this thing.
                        In van jetter 3-5 times a week clean hose and check fluids every use
                        Spartan 758 trailer jetter. 1-15 times a week. clean hoses pressure wash unit every time I use it, check all fluids. Change oil in pump and engine every 100 hours
                        As foe lube and oil and grease I check and lube it every Sunday morning
                        As I have not had a day off in 5+ years. I can’t let thing go
                        I still am averaging 60-80 billable hours a week.
                        Sent From The StoolBus
                        www.appletondrainandsewer.com
                        Appleton WI, 54915
                        1-920-284-7471
                          Re: Maintenance
                          mike, if you don't slow down or get some help, you'll need maintenance too
                          where's the love for the k-60
                            Re: Maintenance
                            Doing so many jobs per day, how on earth do you get the energy/ambition to clean/oil after EVERY single job I hold off on the maintenance if I know I'll have back to back or a job shortly after.
                              Re: Maintenance
                              Rick, seriously.... if you did your work here in Wisconsin you'd find your rear resting on a bucket running a drum machine more often than not
