Gpj?
  • Gpj?
    GPJ?
    Gallons Per Job.
    How many gallons per job do you estimate you use when jetting?
    1.5"-2"?
    3"-4"?
    4" and above?
    Thanks.
    Re: Gpj?
    I can see the importance of your question in one respect.Sometime the homeowner is in a hurry to turn off the water a plumber is using to properly do his job.
    "No need to waste water ya know"
    So a jetter with low pressure and high GPM seems to want to use a lot of water to cut roots versus the Ausie's high pressure low flow concept.
      Re: Gpj?
      Tough one to say since the jobs can be so different. I go joint to joint on 100ft average line, but the tank is always being refilled so I would guess 700-900 gallons on tough jobs and on easy jobs just jetting a few roots sections and a flush 200-300
      Seattle Drain Service
        Re: Gpj?
        really depends on the length, size and severity of the problem.
        there are times i fill the 300 gallon tank and never have to refill it. and other times i keep it filling.
