new k60 new troubles
  • new k60 new troubles
    got new k60 and had trouble with handle sticking, opened it up to check spring and grease is all over it appears something in that main cylinder thingy is cracked where do i send it to get fixed
    Re: new k60 new troubles
    You can get it down to A.J. Coleman.
    Or call Ridge and ask them for someone closer
      is it possible that the grease is so new and things are so tight, it might just need breaking in. have you tried adjusting the clutch to a midway position
        That's it..I'm not getting a K-60.
          Where you at in michigan?
            yes ive adjusted the clutch and something is not right grease is all over the inside of the machine all over the motor, the machine isnt but a few months old, i too thought it may need to be broke in because the handle wasnt popping up but after a while i decided to check the springs and they were good and thats when i noticed grease everywhere. let also note when you put grease in the fitting under the handle it doesnt go into the main chamber where your cable would slide through. with that said any ideas or should i ship her to ridgid
              www.allanjcoleman.com worked on mine. good people. breid...........
                Brock tool in Livonia Authorized Ridgid repair
                  http://www.allanjcoleman.com/ Thats were I would send my K-60 for repair
                  SMELLS LIKE $$$$$$ TO ME
