? k-60 k-50
  • ? k-60 k-50
    i am a drum guy, but i am intrested in sectionals
    so i am wondering can theese machines jump tub traps 1 1/2
    also if the only way is through the cleanout at the bottom of a p-trap
    are theese machines designed for that or would you need the drum attatchment.
    Re: ? k-60 k-50
    K-60 in 5/8"
      Re: ? k-60 k-50
      i use my k-50 with 5/8'' cable in 2'' shower and washing machine traps all the time. when it's a 1.5'' trap i use the k-39.
      i'm sure i can get it through a 1.5'' trap if i needed to, but i don't take the chance.
      nothing wrong with the drum adapter, i just prefer the k-39/ k45.
        Re: ? k-60 k-50
        If your looking to go through 1-1/2" traps the k-50 with the drum adapter will work very well. The 5/8" sectional cable has a hard time going through 1-1/2" traps. but the 5/16" cable makes it a breeze.
        If your looking for a machine to cable 1-1/2" - 6" lines the k-60 will do you well!
          Re: ? k-60 k-50
          You will get around a 40mm trap with a K-39 as it rotates at 600rpm but the K-50 at 400rpm I have not been able to do it as far as the K-60 it also rotates at 600rpm ask Rick as I wouldn`t use one to clear just sinks.
          Tony
            Re: ? k-60 k-50
            I can clear 1-1/2" Cast Iron tub traps with the 5/8" sectional cable and the straight auger.
            PVC traps, usually the 5/8" cable will make it if the outlet of the trap (weir) is inline with the bend. If it's turned, that is sometimes a problem for me.
            I usually need the drum adapter for copper/cast brass traps.
            Rigdid makes a "flexible" straight auger for the 5/8" sectional which I'm sure would make all traps easier.
            The hitch with the 5/8" cable and traps is that the connecter coupling makes the cable rather inflexible at that point, which can make some traps and bends difficult.
            I still maintain that the K-50 is a great all-around inside the house drain machine.
            I use mine on a daily basis with great success (cue Borat with a high five). The drum adapter gives the machine a LOT of versatility.
            I really don't like pistol/drill machines, but had to get my super vee out yesterday for a tub trap bottom clean out (like you were describing). I had to wipe all the dust off first though!
              Re: ? k-60 k-50
              Yep
