k-50 reverse auger
    Re: k-50 reverse auger
    Ok then . Do you run in reverse just to get through the trap /tough spot then resume forward augering Or run in reverse throughout the whole cleaning process ?
      for the reverse auger to grab and cut, it has to be run in reverse.
      did another 4'' comby with roots today with the k-60. the roots were on the back side of the comby and the reverse auger was able to go to the bottom of the comby and turn back up towards the roots. that saved me from going onto the roof or pulling a toilet.
      issue is the comby creates a sharp edge and running the cable reverse causes the cable to auto feed in. to get it back out you need to run it in the forward direction. when going down a comby the proper direction/ with the flow, keep it in reverse to allow it to cut going in and coming out
        i did as rick said. reverse auger works great. i run mine in reverse all the way in. forward coming out. 7/8" cable. toying with buying 5/8". breid..................
