wiped out
  • wiped out
    had 2 unexpected jetting jobs yesterday. first job when like a charm
    second job was an elderly person with caretakers and they've been flushing wipes for 6 months for her and her husband. husband passed away a week ago
    needless to say the master bathroom was plugged and the guest was ok. the 4'' front c/o had wipes in there, but i was able to jet the 75' to the 6'' saddle and clear out the roots and wipes. then i attempted to go upstream from the 1 way c/o. managed to get 52' in, but that was just going into the guest/ good bathroom.
    so i go onto the flat white reflective roof on the hottest day ever recorded in the city of los angeles. 113 i knew i had to jet past the front c/o and then reverse the nozzle from the c/o to the vent. this would allow me to pull the jet towards me from the ground and blast out the wipes.
    of course i have the owners son watching inside the bathroom for blowback. he was suppose to come outside and let me know so i can shut it off jetting from the roof vent to the front c/o, no blowback. reversed the nozzle and retrieved the hose from the front c/o. ending up blowing a sausage of wipes out the toilet with the son watching. this was an 80' run from the roof vent to the front c/o. all the wipes packed together and forced the water back out the toilet. come 7:30 p.m i had enough. packed up the jetter and figured i'll come back today and try to snag them with the k-60 reverse auger.
    so today it cooled down to 103 with 60% humidity back up to the hot roof and start off with 45' and hook a wad. pulled out and went at it again to 75' cleared the toilet and sink. tub and shower back to back still plugged. no luck from the shower with the old school 1.5'' durham fittings.
    back up to the roof with th k-50 and 5/8''reverse auger cleared it and all is well. except mei'm wiped out. too much sun and no fun.
    so the k-60 and k-50 made a 4000# 18 gpm jetter take a back seat
    hot white roof. first pass with the k-60 7/8'' reverse auger. pulled out a clump.
    k-60/k-50 reverse auger catch. this is a mortar tray that i normally set pulled toilets in.
    did i tell you it was hot. and this is indoors.
    look at the temperature and time of day. note the total distance and average speed. getting nowhere slowly.
    Re: wiped out
    Reminds me of a well pump job on a golf course on a hot day and the whole time I am thinking and people come out here and walk around for fun
    But drain cleaning in the heat you have to love what you do
      Re: wiped out
      We don't have flat roofs up here. Looks like you had a rough day, all that sun and all. I don't know why you had a problem with the whipes, the package says "flushable". I stayed in the shade all day, mostly under a house on my belly, then two auto washer boxes installed, and the k-39 down the overflow to clear a tub. Also relocated a pressure regulator and installed a ball valve. Productive day, but my whole body is hurting now.
      The Other Rick
        Re: wiped out
        Rick move to michigan..........it was 56 out and poored ran for two days !
          Re: wiped out
          I saw the temps on the news
          You got the weather we had all summer long
            Re: wiped out
            Was in the 60's yesterday. This does prove what I been saying for years. A jetter has a time and place, and I always rod a line before I jet.
              Re: wiped out
              Sounds like you should have mentioned a toilet seat bidet to them.
                Re: wiped out
                Gee Rick what are you going feel like if you have to do a job like that in 2 or 3 more years from now when your really old
                  Re: wiped out
                  See,I told you service plumbers were wimps.
                  We were working right around the corner from you up two houses from Rookie Plumber's house.
                  6:30-2:30
                  Finished up the gas rough in and knocked out the complete waste on a raised floor 2bath stripped down to the floor joist(no roof).
                  Day before was alot worse.
                  At least now I know when I drag out my drain cleaning equip. I'm eligible for pity points.
                  Once again P-Rick's making my life more pleasant.Thanks Rick
                    Re: wiped out
                    I had it the worst, I tell ya......I sat in my air conditioned office drinking coffee and talking to the best plumbers in the world. It was rough
                    Way to stick with it and get the job done Rick!
                      Re: wiped out
                      adam, weren't you telling me that you packed up early because you couldn't handle the pipe and wrenches due to the heat
                      you said you couldn't work with gloves on
                      no glove, no love
                        Re: wiped out
                        working in the heat like that sure takes it out of one, especially when one is not really acclimated to it,
                        be careful working in that kind of heat, keep your self hydrated, and if you need to take a break and get cooled down do so,
                          Re: wiped out
                          you said you couldn't even work with gloves on
                          no glove, no love
                          Yeah,the day before...Remember,the hotter day
                          And that was at 2:00 after the heat peak.
                          The gloves of love had the fingertips cut off for finesse.Everthing had to be fisted.
                          Changed to gardeners gloves for us to load the Rothenbereger 22A.
                            Re: wiped out
                            You're all wimps! GLOVES ARE FOR WELDING !!!!!
                              Re: wiped out
                              whimps
                              i only use gloves when i tig weld. mig and arc are bare hands
                              i've been using medical nitrile gloves more and more when i drain clean. phoebe doesn't like dirty hands
