pvc to cast question ???? Page Title Module
  • pvc to cast question ????
    I have a customer that has 4” cast stack, it is sticking out of the floor about 3/8 of an inch. is there a way to attach pvc to this pipe. Like a slide in insert type fern co. the cast is a messed up.
    So he wants to put pvc up to this point with put busting up the floor???
    The cast isn’t strong enough to just use a fern co this is his and my dilemma
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: pvc to cast question ????
    i would like something like this?
    Appleton WI, 54915
    1-920-284-7471
      this would be much better for this aplacation
      any clue where to get one and what it is called ???
      Appleton WI, 54915
      1-920-284-7471
        Can you take a hammer drill and go around the cast all you need is 1" for a no hub
          I would prefer not to, but if I have to I will.
          Appleton WI, 54915
          1-920-284-7471
            here is a drawing
            Appleton WI, 54915
            1-920-284-7471
              mike unless you insert a 3'' pvc riser into the 4''. there is no insert fitting.
              i use a core drill and drill a 5.5'' outer hole around the 4'' pipe. then just chip it out.
                I agree with the pp, just chip away. A clampall needs 1 1/2", then you could go full size and just motar the small concrete damage.
                  Do you have the hub or just the pipe?
                  Thanks.
                    he is a pic of the pipe.
                    Appleton WI, 54915
                    1-920-284-7471
                      Unfortunately I think the floor will need to be opened up, in order to make a proper connection. Just do it right the first time and you will be the hero in the long run.
                        Boots look new. You must be doing OK.
                        Rick's right. I think you should plug the pipe off with some rags or a test ball or something then use a dry concrete core bit around the perimeter of the pipe. I would use a clamp all too, instead of a mission, because you have that broken section and that extra half inch may make be important.
                        If you worked in my area I have a Bosch 5" dry core bit for concrete and Bosch Bohrhammer you would be welcome to use. I see you live 5 hours away.
                          The ho opted for a temp fix.”HACK” I told him the floor would need to come up. he said ok next time it back up break out the floor.
                          The pipe wasn’t good enough to even hold a fern co, that far gone..
                          P.S. my boot get pressure washer every time I use my jetter.
                          I have 3 pears
                          Appleton WI, 54915
                          1-920-284-7471
                            I have 3 pears
                            Lemme guess duct tape Gotta love it ..Ijust tell em' no problem and
