Reverse Auger Rides Again !
  • Reverse Auger Rides Again !
    Got a call from a buddy of mine last night. He changed out a wall hung to a pedestal. Ok so far so good . He tells me when he started testing the drain it started backing up. 1 1/2 " galvy. No problem I went there today with my side kick k-60 and got busy. Proceded to remove the pedestal sink.1st head was a 7/8" bulb auger . Not happening.2nd choice small 4 blade cutter head..Not happening.3rd head drop head.. Still not happening .Enough games out came the almighty reverse auger. I put that bad boy on and almost instantly down she goes. I kept working it back and forth through the wet loop about 3-4 times . I was hoping I would not have issue where it turned from the tee horizontal to go down the vertical ..No issues at all .Pulled back some hair etc. put a new galvanized nipple back on reset the pedestal . Then headed over to the tub drain . Same deal 5/8" reverse auger. Removed overflow cover plate and down she went. What a thing of beauty. I am now in the reverse auger cult .I might as well chuck the other heads in my box because here lately they can't cut it And I still haven't opened it up any since I made it or did the heat treat thing . Hey Rick , I have done some tempering in the past . When you say heat treat does that mean heat up the cable where I made the auger and quench it in oil . Will that temper / heat treat it making it stronger and less likely to break at the new cut point . Again Kudos on the reverse auger idea !
    Re: Reverse Auger Rides Again !
    you have to be careful as too much hardening will make it too stiff and subject to snapping and not flexing.
    i heat it orange at the tip to allow me to bend the hook out. then cool it off in oil. grind it sharp, then reheat just to a light color and let it cool. this will give it the softness/ annealing.
    i believe these are the right steps. tool or bhd are probably more qualified to know better
    glad you're a reverse auger believer like me and others.
    now you need the real secret weapon, the 7/8'' reverse auger
      I have one cable that a friend kinked right at the male end he felt bad cause I lent the K-60to him {yes he is a licensed plumber} to rod his house I told him dont wory he wanted to pay for cable and I said thanks but no thanks now I have my cable I can cut and turn into a reverse auger
      SMELLS LIKE $$$$$$ TO ME
        I feel Rick has it right,but will do a thread on the Hobart weld talk forum
          Go to the weld talk [ hobart] forum, I posted
          Heat treating Question under Questions,suggestions,support. { Your brothers need some help} Keep checking their site for info !
            I am just waiting on a 7/8" cable . Then you better believe I will have one of those also
