Are sectionals really all they're cracked up to be?
  • Are sectionals really all they're cracked up to be?
    I'm a drum guy.... and apparently I'm part of a dying breed. I've never gotten my hands on a sectional nor have I ever seen one being used. My question is - what makes a sectional so much better? Are there any posts on the forum on sectionals that I should read? Something to teach me the ins and outs of these machines that are so foreign to me?
    Ideal Plumbing
    Re: Are sectionals really all they're cracked up to be?
    They have a time and place. For me its in a crawl space or a basement that I could not get my Spartan 1065 into. Other than that, I prefer my drums.
    I do use a 5/8 sectional / drum machine Its the Eel Model N I did have a cable made up with a Ridgid male end on it so I can use the Ridgid K-50 cutters.
      I use both but imagine a long steep narrow staircase to the basement, and you think " I can get down but up is going to suck"
      Seattle Drain Service
        I think a lot of it depends on your area. Here an outside clean out is almost unheard of and the majority of basements I go into are in 50-100 year old homes so the stairs are narrow and weak.
        I would say, off the top of my head, I could fit a decent size drum machine down maybe %50 of the homes I enter.
        I don't have much experience with drum machines, I wish I did. they do look a lot more 'user friendly' but I'm thinking a sectional is a lot more versatile, especially when it comes to getting it to the work area.
          Your area is just like mine Gene, The drill and eel set up works wonders in this area. K-60 would be great for the lack of head room jobs and crawl spaces. Drums are great is you have the access safe stairs sit on a bucket and go to work.
          Gene do you have any of the eel expander blades? They really do a number on the roots as a finish cleaning blade.
          Rod
          http://unclognh.com
            The whole idea of sitting on a bucket VRs one section at a time is VERY appealing, but around our area we would need a gurney after getting a drum machine into most basements
              Sometimes I get lucky with bulk head access or basement with a ground level door or garage to bad it was not ground level all the time. Then I could do drains till I was 90
              Rod
              http://unclognh.com
                Personally I have never used a drum machine. I have seen them used and thought they seemed slow, bulky , and underpowered. That being said these were rental units from home depot. So what i'm saying is if I came across the right one that seemed to fit my needs I would consider it. But for right now I am set with drain cleaning equipment. with my k-60 and k-1500
                  My answer is YES!
                  This topic has been argued several times, just do a search on it! enough said!
                    You sure got that right!!
                      Originally posted by jhplumbing View Post
                      My answer is YES!
                      Yep. Sectionals have lots of cracks. At each section in fact.
                      Drums are better. (Let it roll, let it roll)
                        if you do a search, there are literally hundreds of different threads and photos and that's just from me
                        was a drummer, till i got smart. sectional for me for the last 3-4 years.
                        be glad to sell you every drum machine you could ever use.
                          Originally posted by old1 View Post
                          And underpowered
                          rotflmfao !!!
                          A lot to learn you have
                              If the price is right, I may take you up on that offer. I could use something in the 100' - 5/8" range for now until I can afford a shiny new sectional.
                              Ideal Plumbing
