Kitchen drain gone bad
  • Kitchen drain gone bad
    We went out early this week for a drain leaking ..Its a rent house
    one plumber had been out but he wouldn't come back i should have known
    Once i got started i could see why the kitchen pipe had been stopped up but once he went through it water was seeping out the bricks on the side of the house ..its rotted out under the slab and 35ft from the working bathroom
    The washer had been re routed around the house at some point
    so i had a drain that i could use if i could get a pipe to it
    My set up is not quite like some i have seen on the forum but i got it done
    we had to jet in 15 ft to the kit sink and try to avoid hitting a pipe
    The first pic is the old sink cl out i had to get the jack out of my truck to get my cable loose
    Re: Kitchen drain gone bad
    If you look close on the last pic you can see were we had to bust the old line out of the way to get the pipe through it took us 30 min to get it the 15 ft that was the easy part but the job went good
      Poors mans dircection boring. Nice
        Great picture, DELCASE! Where is that fabulous looking store?
          ITs around the corner from a little bar my dad use to visit
          I enjoyed the look around thanks
            well well well, mr Kirk found his way onto the forum too!
            Welcome sir
            -Chris
              Welcome sir
              -Chris
              Captain Kirk
                Kirk is a lot tougher looking than Shatner
