Good or Gimmicky?
  • #46
    Re: Good or Gimmicky?
    I'm going to buy a 2 1/2" one for my K1500.....I am not sure if 3" would be to big....Tom
    • #47
      I see problems when it hits an offset.
      Rod
      http://unclognh.com
      • #48
        Especially if you have some roots wrapped up on it.
        • #49
          For the money you can't beat Electric eel's expander blades they can get by offsets and reset after getting past an offset.
          Rod
          http://unclognh.com
          • #50
            Originally posted by dcman View Post
            I got one (3" version) and it was expensive ($185.00). It does work well, however, it is tough to turn at the bottom of a clean-out, and Plumber Rick is right, if you have a mass of roots, tough to get to pass. Having said that, it is a great clean-up cutter and I don't regret it. Can't say I justify the cost, but nothing ventured, nothing gained! Hope this helps! FYI--I use the Ridgid K-7500 but I like General Wire Cables and Cutters better. (I can just hear all the Ridgid drain cleaners now!)
            WOW...185
            I see a problem if you use it in orangeburg
            Hey I`m using the General cable in my cordless sink machine and was wondering about trying some 3/4 IC in my K-7500 as my ridgid cable is just not holding up.
            • #51
              All Clear Sewer: I put a Ridgid anchor in my K7500, then I take a one foot Ridgid leader and cut off the female end...then take a general wire cupped female adapter and have a welder weld it in place...grind the edges down...then attach a 100 foot general wire 3/4" i.c. cable. I clean at least two sewers a day and I replace my cable about once a year. I just don't like how the Ridgid 3/4" cable runs...I will say that in my smaller Ridgid machines I still use Ridgid cables....so I'm not a total traitor!
              Derek
