Rick's 7/8" Reverse Auger
    Re: Rick's 7/8" Reverse Auger
    Originally posted by dcman View Post
    Thanks guys!!
    Old1-- The way I read your last post, you run all open wound? I am still waiting on two sections of i.c. cable...so theoritically I could be cabling sewers with out i.c. leaders?
    And yes I was monkeying around with that stupid a88 velcro thing...think I will just extension cord up to it...
    Last deal...does nobody make a adapter to allow me to use the buttload of cutters from my 3/4" general wire cable to the 7/8" sectonial cable??
    Yep , I have been running all open wind..No problems so far..I clear sewers all the time with the open wind..A few people on here suggest using the i.c especially on longer stoppages..I guess the i.c cables absorb more of the cable wanting to bind up / spring back .
    Trust me I have had to stop people from un doing the velcro..It sucks especially after it gets wet..No problems I bought a 3 way extension with the light up plug .Thats useful for a drop light etc and to find your cord in the dark
    Not sure about the adapter ..I hope you find it.That would be nice to use the cutters you already have ..Keep us posted on your k-60 adventures
      Thanks...have a 170 foot sewer tomorrow but I plan on using the k-7500...friday digging up water main...so probably be next week till I break it in...BTW...AllenJColmen, AllStarPlumbing, Cable Center, all said they don't make an adapter so since I have like a 1K worth of cutters that pi**ed me off...so I made one
      Derek
        Nice work Like Hannibal Smith from the A-Team said
        "I Love when a plan comes together"
        Rod
        http://unclognh.com
          Lo Pan: [spots Gracie, Margo and Eddie on a security monitor] Who are these people? Friends of yours, huh? Now this really pisses me off to no end!
          Derek
            Nice! Is that for the 7/8" ?
              Yes I can click it on the 7/8" cable then screw in my general wire cutters!
              Derek
                Sweet deal I need to made an adapter for the timberwolf.. I have the male end from when I made the reverse auger ..Gotta do something with it Keep us posted on how you like the 60
                • #23
                  Are you guys running the machine in reverse when using this auger ?
                  • #24
                    http://discountsewercables.com/Sectional%20Cables.html
                    About halfway down the page....it just doesn't mention what size cable it's for.
                    Ideal Plumbing
                    • #25
                      Looks cool...bet its for the 5/8" cable...I'll call today and find out...thanks!!
                      Derek
                      • #26
                        also keep in mind the wire gauge is much larger on the cable/ reverse auger than the funnel auger.
                        plus the weld is 14' 6'' away from the cutting edge.
                        you don't need to buy a cable for this purpose. just sacrifice your older cable that might have a kink or a bad connector on 1 end.
                        So u just whack the male pin end off then make the auger...and this will sound stupid but what kind of oil do you use for quenching?
                        Derek
                        • #27
                          I used a mapp turbo torch to heat the tip then put it in used motor oil. Sharpened it with a regular file afterwards.
                          • #28
                            The make it for 5/8" and 7/8" ...you just have to specify which one you want ...thanks for the great find!!!
                            Last edited by dcman; 03-10-2011, 06:57 PM. Reason: Add: Something like this right?
                            Derek
                            • #29
                              It's also good to have when your cable gets stuck. I made one up with a Spartan end on it. Saved me A#$, my K-60 got stuck bad doing a roof job. Made the adapter, dragged my Spartan 300 on the roof and viola! Got the cable out, no problem.
                              • #30
                                Originally posted by TomSV650 View Post
                                It's also good to have when your cable gets stuck. I made one up with a Spartan end on it. Saved me A#$, my K-60 got stock bad doing a roof job. Made the adapter, dragged my Spartan 300 on the roof and viola! Got the cable out, no problem.
                                What was the benefit in using the Spartan 300 to get the cable unstuck ?
