Rick's 7/8" Reverse Auger
  • #31
    Re: Rick's 7/8" Reverse Auger
    Originally posted by AssTyme View Post
    What was the benefit in using the Spartan 300 to get the cable unstuck ?
    The benefit was that my Spartan 300 got the K-60s cable out, when the K-60 couldn't.
    On this one, the K-60 failed, while my Spartan 300 saved the day.
    • #32
      Are you guys running the machine in reverse when using this auger ?
      AssTyme, I don't. On my machine at least, running the machine in reverse, (the switch), screws the cable into the pipe, forward. The (forward) switch screws the cable in backwards. I think the problem with the cutter end Ridgid sells(T-101), its wound forward compared to the regular cable which is reverse wound. So if you accidentally had the switch on Forward, you could screw the end of the cable onto let's say a broken pipe. Put it the switch on Reverse, and the cable wants to go forward and you could be really stuck. Bad idea.
      Cutting the end off a cable is nothing new. I'm sure it's been done for years on these sectional cables being that there nothing more that big spring. I have both the 7/8 and the 5/8 ends cut off.....
      Thought I read the reasoning somewhere, correct me if I'm mistaken.....
      • #33
        Exactly but I didn't have the heart to tell them They seem so happy with it and so exclusive
        • #34
          What............ is this possible.....
          • #35
            I have never been stuck (<----Lying Like A Rug)
            Seattle Drain Service
            • #36
              Re: Rick's 7/8&quot; Reverse Auger
              speaking of stuck. I just picked up a 4 ton come a long and chain at a garage sale for $20 bucks. Something deep down said buy it.
              Hope I never need it.
              Rod
              http://unclognh.com
              • #37
                We got an EEL cable stuck one time and my dad got a wrecker to hook on it and try to pull it out. The wrecker just stretched the cable out and didn't pull the cable out. I tried the come along one time but couldn't find any where to hook the other end up to. Kind of like the time I got my truck stuck, I had 12 FT of cable and not a tree for 200 Ft and the dead mans anchor just pulled up out of the ground. But sometimes it dose work so good luck
                • #38
                  How'd you finally get the cable out? what was it stuck on?
