Ridgid 7/8 with plastic I.C
  • Ridgid 7/8 with plastic I.C
    Anyone use the 7/8 cable plastic I.C with the K60?
    Any good? Junk? General makes a wire I.C 7/8 cable
    Plastic! it can't be any good? I'm used to running the eel 1.25 cable
    Rod
    http://unclognh.com
    Re: Ridgid 7/8 with plastic I.C
    This may be helpful to you. Hope Gear is well...
    http://www.ridgidforum.com/forum/sho...t=Rothenberger
      Thanks J.C
      Rod
      http://unclognh.com
        i have both the ridgid c-10ic and the general ic.
        the ridgid i run the first 15' section with great results. the nice thing is the roots are easier to get off the cable as they only get in so deep. plus the overall weight is a few pounds lighter. makes a difference if you carry 90' in the cage, the weight adds up.
        the plastic core makes the cable less prone to flip. since it's not actually attached to the ends, it's there to allow the cable to torque and stiffen it from flexing over.
        i like the ridgid c-10ic. problem is the availability and the list price
        the general is less money and easier to get.
          Thannks JC iforgot all about that thread.
          Im a General guy myself
            I been thinking about that lately as well.
              Got my ridgid innercore from Allen J. Coleman and he said he was going to start stocking it. Havent checked the price lately. I wish i had enough money to have all innercore because it is easier to clean roots out of it.
                I use the general IC (60' in front) if I'm a straight run of 6"
                If I need to make a couple of turns, I put the Ridgid IC in front followed by the 60' of general IC.
                Almost all of my lines are 6" - 75'+
                If it's 4", I usually just use the regular C-10 unless it's a particularly nasty blockage
                -Chris
                I got ALL of my cable from AJ Coleman too
