Jumping Secrets?
    Re: Jumping Secrets?
    Originally posted by handybull View Post
    Gene what was the hard way?
    Just the way the place was set up made option 2 a PIA.
    Had to drain the system, set up tarps, move a bunch of things, snake overhead, pump the drained water back into the system when done etc..
    I think I jinxed ourselves when I saw option #1 by saying "oh, no problem. this is going to be easy. We'll be in and out"
    It really was not that bad but option #1 would have been soooo much easier.
      Originally posted by OLD1 View Post
      Sorry J.C .Had to do it.....I went on a call yesterday. Basement drain for a laundry tub. 1 1/2" DWV copper .k-60 5/8" cables. I have every head known to man. Not happening . The waste arm hit a 90 that turned right into a dwv t wye.. I tried different heads while the home owner was watching carefully. Don't worry I have all kinds of secret weapons.See that cable there..Out came the reverse auger. I got things flowing quick, fast, and in a hurry. Then I have a bulb auger that has a nice bend in it .Not sure how that happened. Ran that puppy . Then hooked up a hose to the laundry tray faucet and power flushed it. Hooked the drain back up and Woooshhhh! Coreolis in full effect..You could hear that drain sucking all the way upstairs. That cable is wort it's weight in gold. So is my 7/8"
      Thanks. Might have to cut the end off of a cable soon. Just hate to damage something that is functioning as it is. No old damaged cables to do it with....yet.
        if the reverse auger couldn't get through the bend, nothing will.
        the trick is the bend at the end and run it in a forward rotation so that the reverse hook actually slips and not grabs. once through, run the cable in the reverse rotation and you've got a giant corkscrew.
        3 '' pvc 90 should not be an issue. heck, i get the micro drain through 1.5'' pvc pressure 90's as in pool lines
          Just buy a new cable and replace one of your older ones. That's easy .The 5/8" are around $20.00 . It's only money right? Sometimes sacrifices have to be made.TRust me there will be a lot more of this and a lot less of this Like Rick said if the reverse auger won't get it nothing will. My only problem is I have been running mine in reverse going in and coming out..So far no issues
            Just regained consciousness after reading that. Taking it all in now.
              Me too. Makes that front end jump through the turn. That's a conduit 90 though. I haven't ran into one of those before. Makes the sectional pull and push like he!! at times.
              What, exactly, is that 90?
              it looks tighter than a usual dwv one, and the 'conduit' I know of is electrical conduit, and it's grey, and comes in nice long sweeps.
                could it be black abs pipe and a 3'' vent 90
                i think the lighting from the microexplorer makes it look greyish
                but you're right. an electrical conduit pvc grey 90 would be a long sweep with only 1 built in coupling.
                why anyone would use a vent 90 is beyond me when there's all the room to install a 1/4 bend. plus vent 90 is more expensive and snaking a 90 is more difficult than a 1/4 bend
                • #23
                  That's probably the only 90 the installer had left and that vent was probably the last part of the job. I've seen people do things I don't agree with just because they're short on materials and don't want to make the extra trip to get it done right. What does he care, right? He's only there to install it, he doesn't have to worry about snaking the line.
                  Ideal Plumbing
                  • #24
                    If you look at a CI closet bend, there is no sweep to it. So, essentially a CI closet bend is a "vent" 90 with no sweep. That fitting looks like the old Clay schedule 40 or schedule 80 that preceeded the white schedule 40 that we know and love today. I see fittings like that a lot in homes remodeled and/or built in the 80's.
                    I have a bulb auger with a gnarly bend in it that I use for sharp bends like that.
                    I don't have a reverse auger, but I have a job for tomorrow that may force me to make a reverse auger to try on.
                    back to back tub/shower in a 20-bathroom condo on floor 7 of 16. 30 y/o building. The maintenance guys already tried rodding, twice, and only managed to create a leak into the unit below. And the unit was vacant for almost 2 years My bet is on rust/scale from the pipe sitting dry for so long, but who knows!
                    Should be a fun one!
                    -Chris
                    • #25
                      That was funny...Breathe in breathe out. It's all good
                      • #26
                        Yep, that's absolutely a 3" vent 90 elbow. Why use on if you're not in a tight spot? If you're in a real hurry to get the pipe installed there's no fitting allowance to subtract.
                        • #27
                          You fellas' got any "jumping secrets" for a transition like this. Had a whole place backed up and this is the bottom of the 3" vent I have for access. Wanted to whoop an auger in there but kept catching and/or wouldn't jump the turn.
                          Thanks.
                          JC, What did you do with this drain?
                          It totally avoids the spirit of the discussion of getting around a tough turn, but since there's room for the fitting, and apparently access (based on image) why not just cut that fitting out and install a regular DWV 90? If you cut the pipe at the edge of the hub the regular 90 should fit. Since the 90 starts out flat I assume it's well above the backed up water level.
                          Then you go on about the business cleaning the drain? You may be back in the future and then the job will be easier.
                          • #28
                            I cleared the drain, just as asked.
                            I have sent a report of conditions with some pics to the owner in GA for them to consider. Many things wrong at this place.
                            Wrong. Sorry. The whole place was backed up to about 2' above this 90.
                            Could be. Have told the owners this also.
                            Thanks.
                            • #29
                              Almost forgot, some asked about the 90. This area looks to be plumbed in a grey PVC. It is not Sch. 80. Looks like UV rated PVC or Conduit.
                              The 90 is the same dark grey material. Like a true "Vent" 90 except used at the bottom.
                              • #30
                                If you dont have one yet, get a trap leader for your cable. Part 63090
