IC cable??
  • IC cable??
    Do you guys recommend IC cable or not? I will need to order a 3/8 cable for a k50 just wanted to know input on type or brand of cable to go with?
    Thanks
    Re: IC cable??
    Shouldn't be needed on a sectional.
    On a drum machine, that's all I use.
      Re: IC cable??
      The 3/8 cable is a drum for the K-50 and yes IC cable is the way to go.
        Re: IC cable??
        Ditto from me on the IC in 3/8.
        If I find myself using 3/8 cable with the K-50 and drum attachment, I'm usually in a 2" K/S line that dumps into 3" or 4" within 20' and I want a cable that is stiff enough not to flip easy in larger pipe.
        ....but I usually use the 5/8 sectional cable with the k-50
          Re: IC cable??
          does anyone know a part number for the ridgid 3/8 ic cable for the K50 adapter?
            Re: IC cable??
            The c-6ic cable is 96037 list price 81.05 marvin
              Re: IC cable??
              Thanks for your response Rod Man i will be ordering that cable! Do you also recommend a IC cable on a drum unit? i'm using the K50 with adapter.
                Re: IC cable??
                I am an IC fan I just orderd 5 general 7/8" IC for the K-60 $53.00 each new thats 12.00 more then I get my C-10 cables for
                SMELLS LIKE $$$$$$ TO ME
