End Broke Off Cable....
  • End Broke Off Cable....
    This was on a 5/16" bulb head cable, #8 style end broke off exactly where the weld ends on the 3rd use. Could this be blamed on improper welding ?
    Re: End Broke Off Cable....
    Is it Ridgid?
    Thanks.
      Is it Ridgid?
      Thanks.
      It was in my K-39AF but it's not a Ridgid cable.
        What cable was it?
          not uncommon to snap off a drop head bulb auger.
          the reason why my reverse auger works so good and doesn't break is the fact that it has 7' of 5/8'' spring leader before any welds or attachments. the 7/8'' has a good 14'.
          the weld can easily weaken the cable at that point. while the rest of the cable can flex. the weld stops the cable from moving and absorbing the spring tension. a 5/16'' cable is not a heavy wire gauge.
            That's what I was thinking but I wasn't sure. So I guess I can't call and ask for a replacement because of poor workmanship
            ThanX
              i would think you overstressed the bulb when you got it hung up in a 90 or the stoppage.
              i never use a drop head unless it's 100% necessary. i've also broken my share of dropheads
              but never broken a reverse auger plus they're free
                WHILE ALL OF THE ABOVE IS TRUE !
                I WOULD STILL CALL THE CABLE MFG,
                THE WORST THEY CAN SAY IS NO ?
                YOU DON'T KNOW, MAYBE THE WELDER WAS HAVING A BAD
                DAY OR JUST GOT IT WRONG ?
                JERRYMAC
                E-MAILJERRYMAC777@GMAIL.COM
                FIRE SPRINKLER CONTRACTOR,
                SINCE JAN. 1989
                  Great,
                  Gimme One.
                    Is it Ridgid?
                    Thanks.
                    J.C.'s darkside?
                      Great,
                      Gimme One.
                      i did let you borrow the beta version. you were the first outside of plumber rick to lay thier hands on it
                      and you know you love it
                        I remember.That one was the 2'.I'm still waiting for one of my 7/8" to give out.Over two years...Break already!!!
                          I just did an online U.T. of the weld. It's fine , operator error
                            It looks like a spartan 5/16 ic cable marvin
                              New cable was sent out today. No hassle, no questions asked
