Sink/Tub Machines
  • Sink/Tub Machines
    Many use a gun of some type. Do any use the type that sits independently?
    Ever used them before?
    Examples:
    Spartan
    http://www.spartantool.com/machinevi...hines&model=81
    http://www.spartantool.com/machinevi...ines&model=502
    Ridgid
    http://www.ridgid.com/Tools/K40-Sink...e/EN/index.htm
    Gorlitz
    http://www.gorlitz.com/drain-cleanin...nt/info_5.html
    http://www.gorlitz.com/drain-cleanin...t/info_11.html
    Electric Eel
    http://www.electriceel.com/
    (Model CT-No direct linking. Like a Ridgid K40 with variable speed.)
    General Wire
    http://www.drainbrain.com/pro/4drainrooter.html
    Others? Good or bad experiences?
    Thanks.
    Re: Sink/Tub Machines
    I use the gorlitz go15 with 1/4 inch cable for bathtubs to protect the waste and overflow.
    If the tub is not full of water I line it with newspaper and remove the guide hose.
    If the tub is full of water I put newspaper on side of the tub and use the guide hose.
    I consider this my tub machine and rarely use it for anything else because of the small cable. The cable is small enough to not damage the waste and overflow.
    The 50 foot cable is too long to fit in the reel so I use 35 feet. Also the enclosed reel makes it rust quick. I prefer open reel. Other than that it's been great.
    Any sink from pulled ptrap I use GO 50 with 3/8 or 1/2 inch cable. 1/4 is just too thin for 2 inch IMO.
    Gun type machines are a two man job IMO which is great if you have a helper. Otherwise you have to hold the gun with one hand and guide the cable with the other. I can't really control a cable with just one hand.
      Sinks and tubs are two different birds. 1/4" to 5/16" drill type for tubs. 5/16" drill type for short easy runs on sinks. Spartan 100 with 75' of 13/32" for stubborn or longer runs.
        True for the most part if you have no auto feed. I have three K-39AF's, each with a different cable/cutter setup and absolutely love them.
          I like to use my 50` cordless on tubs/sinks
            I use the ridgid K40 on bathtubs, General Mini-rooter on sinks, the 1/4 cable I have in the K40 is too flimsy for me to hamfist it through a sink blockage.
              Tubs & sinks get the Electric Eel model N with a 5/8 cable . It goes right through traps easy and feeds it self after the first turn
                JC, I use a Kenway and have three different drums /cables with it. I've had this thing since 1984. It's getting beat up and ugly, and still uses an electric foot pedal. Strange, the older and uglier it gets the more attached I am to the darned thing.
                I would take a pic of it, but there's no point in needlessly scaring folks.
                  I have been kicking around the K40 with the battery. Marvin has a few in stock, maybe next time I head there I will pick one up.
                    k-50 with the drum adapter for most, sometimes with the 5/8" cable.
                      I use my Eel Model N with 5/8 cable for kitchen sinks and lav sinks Bathtubs I use my K-50 with a drum. But like I said I do like the way the K=40 is laid out.
                        Seems too large to get through traps & strainers. No?
                        Thanks.
                          K 50 all the way here. 1/4 cable for tubs. 5/8 for most kitchen sinks. 3/8 for lav sinks
                            Trust me when I say this... "SAVE YOUR MONEY"
                              How many feet of 5/8" cable does the drum hold ?
