Am I worth it?
  • Am I worth it?
    Hey guys, Advice please. Am I worth getting paid even I can't dislodge or discover the cause of a plugged drain line? Hint: I have an angry customer.
    Re: Am I worth it?
    more info would be great
    I will always charge for a job mainlines . But I might not charge full price if I can’t figure it out.
    That’s why a camera and locator are a must have.
    If it is a smaller pipe 1 ½ - 2” old cast or copper I always charge.
    Just my 2 cents worth
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
      Re: Am I worth it?
      No
        Re: Am I worth it?
        if i'm brought in for a second or third opinion, i will charge as i already know there is a chance it's not going to work and i explain it to them in advance.
        but typically i don't charge on a common stoppage that i can't get through. the most common would be a fixture drain that the cable goes up and not down.
        but this is a rarity and is less than 1 time per year.
          Re: Am I worth it?
          If I can not get the line open, in most cases I can tell why I can not(collapsed, broken pipe). I explain to the owner that they paid me to stick my rod in their drain and try to open it. When I pull the rod back and I see that the cutter is all shinned up (collapsed pipe or full of gravel), or full of clay (broken pipe cutter left the pipe), that they know two things that did not know before I stuck my cable in their line. First is the distance of the approximate distance where the problem is and second they have a broken or collapsed pipe. Now they have to pay me for my time spent. As my father always says "Labor is never free"
            Re: Am I worth it?
            I like Your Dad ! I'll remember this moving forward
              Re: Am I worth it?
              I told the customer I get paid for my time. It was a Saturday. I didn't charge a higher rate. I used my Rigid 400 1/2" @75' and a General with 5/8" @100' both twice full length and no progress. He didn't want to pay me to try again. The next day he hired a company who cleared the line with a 1/2" cable@75' on the first shot.
                Re: Am I worth it?
                what type of line ?
                Appleton WI, 54915
                1-920-284-7471
                  Re: Am I worth it?
                  No....If a drain cannot be cleared due to tech or plumber error then I don't think there should be a charge.
                  If the line cannot be cleared due to break, crushed sewer then yes because have spent the time to diagnose the drain problem. If another company came in and cleared the problem fast then you were doing something wrong and should not charge.
                  Rod
                  http://unclognh.com
                    Re: Am I worth it?
                    Originally posted by appletondrain View Post
                    what type of line ?
                    Yeah, thats what I'm wondering?
                    Sounds like a main. 3", 4" ? If thats the case I'm not so sure K-400 is the right tool for the job.
                    That would kind of be like nailing roofing shingles with a pair of pliers and expecting more $ because it took so long.
                      Re: Am I worth it?
                      Ouch !!!
                        Re: Am I worth it?
                        If it was a sewer line the 1/2" cable was small
                        But the other co used the same size cable
                        It could have been a paper slurry almost ready to flow and the 2nd crew gave it the final stir
                        If it was outside I would have put the blow bag in the line and gave it a push before i gave up
                          Re: Am I worth it?
                          If I can't get a line open, I DO NOT charge anything, as I didn't fix the problem they called me out for.
                          I don't have extensive drain equipment like some of you guys have, and once in a while it bites you in the a$$ by not having the right tool for the job.
                            Re: Am I worth it?
                            But you loosened it up for him.
                              Re: Am I worth it?
                              im not sure how long you have been doing this work but if i ran into a problem where i could not fix something i would not walk away .i would ask some other people to help even if i had to pay for there time . this way i would not loose a customer and they might tell friends that you hung in there to finish the job
                              some times you have to loose a little and you will get back 2 times as much with the next call from them
