I'm now a k-60 owner
  • #31
    Re: I'm now a k-60 owner
    Originally posted by All Clear Sewer View Post
    Thats why I use my K-7500, it has wheels
    My DM-55 has wheels too you should see some of the places I work in
    No room to get a machine in. If I did not have a drill and eel set up I would have said No way and left
    Did two sewer calls today first one K-60 worked great tuff access done in no time.
    2nd call easy access said I'll use the k60 again. Willow tree K60 met it's match Had no IC. Had to use my drum machine
    Over all the K60 will come in handy
    Rod
    http://unclognh.com
    • #32
      Yea I too found out that the K-60 has no power but at least you have it for those jobs that you dont need power on.
      • #33
        takes geting use to just keep trying but remember no its not as powerfull as the drill but if you keep working at it and go with a smaller saw tooth cutter like the T-109 or the T-110 just a thought not trying to tell you what to do just sugestion as thats what I run first with sucsess
        SMELLS LIKE $$$$$$ TO ME
        • #34
          My T-110 came in yesterday That root job was tuff even for the drill
          The two machines Drill and DM-55 got 99% of all the roots out. Took around 4 hours to remove around 60 feet of hard packed Willow tree roots
          Line sat dry for a few years. Can't wait to try the K60 with IC cables
          Just from what I felt running the K60 on those two calls it's going to be a good machine to have worth every penny.
          Rod
          http://unclognh.com
