Weird Drain Part 2
  • Weird Drain Part 2
    Ok The rest of the story!
    A special thanks to Rick! He helped be use the tools I already had on hand. And thanks to everyone also.
    So I ended up using my little spartan 100 to go out to the manhole, then I taped my 3/8 Warthog with 3/8 line to it. Then pulled the jetter nozzle back in to the side sewer line. I already knew where the trouble spot was 25' back from the manhole so I put tape on that marked spot on my hose and pulled it back in towards the house. Fired up the jetter (just one motor) and let it rip! About 5 min. later a major gush of water came blasting by! Now it was camera time! It was a bad line because of about 20 offset joints and a belly. But right now they are using the line and budgeting to replace the line at a later time. So it all worked out for the customer.
    Seattle Drain Service
    Re: Weird Drain Part 2
    good job at getting the drain open
    SMELLS LIKE $$$$$$ TO ME
      Surprised to see a man hole in a driveway, We don't have that here.
      Great fix, Rick is valuable to all ! I'll be over to change out that Mission coupling to a proflex shielded Mon.
        Re: Weird Drain Part 2 BRICK LINED MANHOLE SEWER !!
        Am I the only one that appreciates this labor? I look at the the simple beauty in the brick work, and wonder! Was it an Italian, Swede,
        Irish immigrant ? Was the average one a day for Mason and helper?
        Hand dug ,I imagine , no breaks ! We all came from great people!
          The manhole is actually in a weird little alley that cuts the block in half most people don't even know it's there.
            Congratulations Cuda.
            Had to have been an awesome feeling seeing that line open up.
            You're the hero in that house AND to their friends.
              well done.
              Nothing like jetting up from below the problem; makes it so smooth.
              The art in drain cleaning is all about the access.
                I like the saftey fencing around your job! Nice touch and a help to CYA.
                www.ClinkscalesSeptic.com
                  20 offsets and a manhole in the driveway? It just shows to go ya. You never know. Way to stick with it.
                    Tool: Did you by chance mean change out the Proflex to a Mission?
