Ridgid 62920 T110 2-1/4" spiral cutter ???
  • Ridgid 62920 T110 2-1/4" spiral cutter ???
    Ridgid 62920 T110 2-1/4" spiral cutter is this for 7/8 cable???
    I'm looking to find a smaller spiral cutter for 3 inch pipes with roots
    going from 3 inch toilet flange to septic tank baffle??
    I can't go on roofs in my area roofs are to steep!
    We also get heavy snow and ground is now frozen so digging septic tank lid is not an option.
    I have the T-111 looks like it can get stuck easy in 90's
    I was looking this blade up on Tool-up but they don't list if it'd for 5/8 or 7/8???
    Would this be the best root cutter to snake threw the 3 inch toilet flange to septic baffle with or is a better cutter??
    Rod
    http://unclognh.com
    Re: Ridgid 62920 T110 2-1/4" spiral cutter ???
    Maybe get some adapters to run your favorite cutters ?
    http://www.discountsewercable.com/ told me in an e-mail that they have several available @ $26.95 each.
      Was looking at those might be a problem! The adaptor, blade holder and cable end may make the cable to stiff to make the turn in a 3" toilet flange and 90 into the septic baffel and get stuck
      They look OK for normal 4" and 6" sewer lateral's I'll get it for that
      Rod
      http://unclognh.com
        i have a "c" cutter. looks like a "snarktooth cutter" only it's about 2 3/4" so i guess it not a ridgid. came with my used k-60. i have good fortune with it. in other words i can get it in and out. i also use a a t-102 funnel auger on a cable with a slight kink in the end. last but not least is the ricksters reverse auger. septics are the worst around here. up until recently any body could put in a septic system. no inspections. now they put them in on saturday and sunday. rip the sod like a landscaper and there is no evidence. breid...........
          Rod I run the T-110 in 3" lines no problem with my K-60 as that is what I beleave is what you may be asking and it cleans the line very well and yess the T-110 is for the 7/8" cable
          Last edited by post plumber; 12-06-2010, 08:50 AM. Reason: red title a little closer
          SMELLS LIKE $$$$$$ TO ME
