K60 blades???
  • K60 blades???
    Was on the Ridgid.com site and looked at the k60 parts not much for k60 blades. It there more blades they don't show?
    Rod
    http://unclognh.com
    Re: K60 blades???
    you'll find that ony 4 different blades will do 99% of your work.
    the spiral sawtooth, the pear blade, the 4 blade and the infamous rick reverse auger
    the 1500 blades will also work with the 7/8'' blade holder. not the coupler, just the blade holder.
    i've also machined my own blades to fit the holder. 3'' x 4'' offset cutters are a good choice for 4'' cast iron with 90's.
    i did these on the mill, but a good die grinder/ dremel will also work to cut the rectangular slot.
      Re: K60 blades???
      I am thinking I have every cutter thay make for the 60 and then some . Like Rick said you can geta little creative and create your own custom heads as well..
        Re: K60 blades???
        I was at AJ Coleman yesterday, and I was right Marv has tons of different 7/8" cutters. He has some original Carl Coleman cutters custom cutters. Sorry I did not get some good pictures. He does have some 7/8" chain knockers that look like Rothenberger but are Carl Coleman made. But next time I will.
