Basements?
    Re: Basements?
    I've been looking at getting a little truck crane for my cube van. The speedrooter isn't bad popping in and out when its decent weather but when its slick and icy I've wiped out a few times. Harbor freight has some and I've seen a few other i just don't know if it will be more trouble than its worth, my van box is pretty high so ramps aren't a great option. By the way 95% of our c/o are in the basement.
      Re: Basements?
      We use a lift gate on our van
        Re: Basements?
        Originally posted by AssTyme View Post
        Good feature in theory but it would add a considerable amount of weight and bulkiness.
        And let's not forget the extra $$$$$$$$$$$$$$$$$$$$$$$$$...The stair climbers I have seen were $1200 themselves .New and used the motorcycle type battery that you need to keep on trickle charge like a battery tender or when you go to use it will be dead... They work great for cast iron tubs though
          Re: Basements?
          i think 1200.00 bucks would be money well spent and I don't have money flying out of my butt either. I've thought of trying to build something but i figure I would have $1000.00 wraped up in parts for something that doesn't work. I know I have piles of parts from other projects I thought i would build.
            Re: Basements?
            Stair climbers What? I'm so RICH from making money drain cleaning I just leave the brand new machines in the basement after I'm done clearing their drains. Ha lift it out of the basement are you kidding me?
            Stair climbers Ha ha ha. I don't even need a van I have the machines shipped over night VIA UPS when I'm done.
            Give them a bill for $5,000 for sewer cleaning. Enjoy the machine Mrs Jones
            I just light a cigar and say "I love when a plan comes together" And fly away on my flying carpet.
            Rod
            http://unclognh.com
              Re: Basements?
              99% of the sewers are in a basement for me. On the rare occasion I get lucky and there is an outside cleanout.
                Re: Basements?
                Same here and when you get the outside clean out jobs you feel like you won the lotto
                Rod
                http://unclognh.com
                • #23
                  Re: Basements?
                  A basement here is an oddity. slab on grade or crawlspaces are the norm. If there is a basement, it's usually 'garden level' finished living space. For me it is usually about pulled toilets for access when there is no exterior c/o (or it's under 3' of snow and no-one knows where exactly or even for sure that it exists) and the interior one got dried in.
                  • #24
                    Re: Basements?
                    Originally posted by saysflushable View Post
                    How many of you guys do most of your drain cleaning in basements? I'm just curious, I thought an electric staire climber on our machines would be a good addition and a big help. Maybe I'm the only guy that has to get a machine up and down staires regularly. maybe I'm the only plumber that thinks this is hard to do and trust me my drum machine is easier than most to get up and down staires but it is still a pain in the back. I know mytana thinks I'm nuts for asking about it. I wounder what Ridgid has to say abou it. Josh??????
                    You're definitely not nuts! 99.5% of my sewer cleaning jobs are in basements. A stair climber, or better yet, anti gravity dolly would be very desirable.
                    If the stairs are steep or my back is sore I might get help bringing the Spartan 2001 up or down. If I can't get help I'll just break it down and remove the drum. It's not really that big of a deal. I just hate to take the time plus more trips up and down.
                    • #25
                      Re: Basements?
                      Now that's worth $1,200 bucks
                      Rod
                      http://unclognh.com
                      • #26
                        Re: Basements?
                        I need to have 5 months to myself, a computer in a dark room and some tools, raw metal and I bet I can come up with an answer to this riddle.
                        How can weight be an issue when the cure solves the lifting aspect of the problem?
                        • #27
                          Re: Basements?
                          95% of the sewers here have basement cleanouts. The slab Houses usually have inside cleanouts. IF they did not get walled over. I hardly see an outside one. If I do I know they had to have it installed and have a problem line
                          • #28
                            Re: Basements?
                            I worry more about bulk than weight. Rick said his dolly is only 80 some odd pounds. Thats not too bad . We still haven't heard from Ridgid, maybe something is in the works and they can't talk about it yet!!
                            • #29
                              Re: Basements?
                              Funny thing now that the weather has turned cold and crappy I've had 3 outside c/o's this week. I don't get 3 o/s c/o in a month.
                              • #30
                                Re: Basements?
                                because you still have to drag it through yards that can be soft grass or soft dirt
