k-400
  • k-400
    Hi,
    Would the 1/2'' cable on the ridgid k-400 comfortably negotiate bends in 50mm pipework? I have seen instructions saying use 1/2'' cable in 75mm to 110mm pipe but also other information which says the cable is suitable for 50mm pipework.
    Thanks in advance.
    Re: k-400
    I use the K-400 for almost all of my kitchen sink work. I regularly use mine in 1 1/2 inch PVC lines (39mm) so 50 mm should not be an issue. I recently ran into a problem where the stiffer cable of the K-400 would not clear a drain but the more flexible 5/8" open wind with the reverse auger would.... My guess is that the stiffer cable was hitting a fitting it could not push through...
