Heavy Garage Grease & Jetter Additives
    Re: Heavy Garage Grease & Jetter Additives
    I have a good friend that owns a carpet cleaning business. he uses alot of different chemicals and degreasers to run through his carpet machines....which are basically a pressure washer with a vaccum. I will report in a few minutes.....stay tuned
    He said he has tried all types of expensive degreaser and "Purple Power" works the best for him.
      Follow up......He says he likes the purple power because it doesn't FOAM up as bad like some others do and it cleans just s good or better than the xpensive crap.
      I could see where too much foaming would not be helpful.....
        Purple power is good stuff. We use it as a degreaser on our equipment and on our portable toilets. For reference it's like super clean.
        www.ClinkscalesSeptic.com
          Originally posted by SewerRatz View Post
          I have done that with a super vac truck when I have them on site. Works pretty good on shorter lines. Wish there was a good way to send a vac hose down the line from a super sucker, that would be a great way to clear all this muck out of the line.
          If you can get an end of the line open you can attach a piece of pipe to the end of the vac. hose. We do this when pumping cesspools with little access.
