Can anyone guess what I’m am doing ?
  • Can anyone guess what I’m am doing ?
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: Can anyone guess what I’m am doing ?
    cleaning chimneys,
    I some time ago, made an adapter for a 3/8" pipe so I could chuck it into may 1/2 cordless drill and clean mine that route, also made a simple chain knocker to beat harder chunks off,
    we had some wood that would coat the pipe with a glass like creosote coating, the normal wood we burn just puts a flaky build up, and the brush works well,
      Edit
        Originally posted by Gene Bickford View Post
        DAMN!!!!
        I just bought a chimney brush the other day to do the exact same thing but I am going to adapt it to my 1.25 cable.
        I made one with wire rope as a finish head for roots and it is awesome but so short I have to go very slow. I think the chimney brush solves this but it has to be shortened in order to pass any fittings.
        When I was at AJ Coleman's I seen chimney brushes there for the 1 1/4 cable. Should of taken a picture.
          When thinking about how to make the chimney brush work, I came up with an even better idea. A sort of two in one type thing.
            OK, I guess it's time for my meds and aluminum foil hat.
            I'm starting to get that feeling again that the government is somehow tapping into my brain and giving my ideas away
              Building a brush attachment for your drain machine to clean out dryer vents.
                Could be a brush for cleaning the center flue of a gas water heater tank, after you pull the flue baffle out of course. The propane water heaters soot up pretty bad sometimes.
                  Is that my dryer line brush ?
                    Re: Can anyone guess what I’m am doing ? YES YES YES
                    Any country Boy recognizes THAT !!
                    When that brush is soaked in Kerosene It's a " MULE STARTER " Corn cobs also work!
                      You're making one he!! of a back scratcher.
                      www.ClinkscalesSeptic.com
                        cleaning weld blobs off your floor?
                          Thats what I was thinking..or learning how to weld. just a joke!!!!
                            Saving a butt load on toilet paper
                            Rod
                            http://unclognh.com
                              Sounds painfull!
