K3800 repair
  • K3800 repair
    I am having a problem with the motor not engaging the drum securely and believe the pins that spin the drum are worn. Has anyone ever replaced this part, the output shaft assembly, before?
    Re: K3800 repair
    If you can hold the drum and the motor runs the output gear is probably slipping. The output gear is made in 2 parts and i have seen them slip marvin
      Re: K3800 repair
      He is the man If anyone will know its marvin he probably has the parts on hand to
      SMELLS LIKE $$$$$$ TO ME
        Re: K3800 repair
        PS welcome to ridgid forum
          Re: K3800 repair
          And a 2nd set under His bed at home, in case Mrs. O' Leary's Cow Kicks over that Latern again !!!!!
          You OLD FARTS can explain that to the Kids.
