Marco cable in General Machine
  • Marco cable in General Machine
    Just wondering if anyone has ever used a Marco 5/8 cable in A general mainline machine (up to 3/4 cable)? Here in hawaii getting the correct parts can be hard.
    Re: Marco cable in General Machine
    Shouldn't have any problems....I'm using a Spartan cable in a Marco machine....
    If the machine uses an anchor cable, you'll need to put the correct end on the anchor to attach the new cable.
    Ideal Plumbing
      I use a Ridgid drum with a General Wire cable...but as mentioned before me have to keep same brand anchor in machine....
      Derek
        You can keep the Ridgid anchor in your machine they do make an adapter to go from Ridgid end to General end.
        Thing is General, Ridgid, Spartan, Eel, and most other manufactures all use left hand wound cable, so you can always get the cable you like and install the your preferred ends. As you can see in this picture from Drain Cables Direct there are a handful of different types of ends.
        Now here is the thing about Marco, their cable is right hand wound. The ends in the picture all will only screw into left hand wound cable. So no matter what machine you have if you want to use Marco cable you have to use their anchor, but if you want any other brand cable you can use any anchor of your choosing as long as you have the matching end of your choice.
          HMMM....very interesting...but don't know much about Marco...but I learned something today!
          Derek
